Now i know it flies well i have started making some detail pieces for it,started with the guns,in the past i have used the Balsa Usa guns which are good and give a good effect for a gun made of wood.This time i decided to try and make them from scratch,the main focal point of the Spandau is the barrel shroud,so i started with this.I cut two pieces of litho exactly the same size and taped them together,marking all the holes took an hour and a half,i then drilled all the holes out then cut out between the holes with a stanley knife,i just have to tidy it all up with a needle file.I then rolled them around a piece of tube cut a 5mm strip of litho and glued it over the joint with Isol.
- 002.JPG (132.55 KiB) Viewed 6349 times
