Made some good progress on this longstanding project over the winter. Model now structurally complete and just finished the nose-cone and doing final filling/sanding prior to glass-clothing (Maestro Johnson's going to do that for me as he reckons I'm s--te at it!!).
WV507, the subject...
The full size T11 has some strange curvatures on the extended nose (see pic' above).
Nearly done. Turbine, radio & retracts in and working; main leg doors to fit. Finally, canopy fitting when I receive my pilots from Wilson Li (Tailored Pilots) in the New Year...
Repairs and reinstallation completed. The 'sit' with the shortened nose-leg & mountings moved upwards in the nose, looks much better now. Decided to check with DJ as to the CG position on his Sterner Vampire after he'd had a near thing and added nose-weight subsequently. My CG turned-out to be 3/4" rearwards of his which obviously didn't help with the prang... The addition of 1lb lead up front has corrected this. As to test-flights - your guess is as good as mine!
