Page 1 of 2
Bigtilla
Posted: February 14th, 2011, 7:10 pm
by Barrie King
Just thought I would share with you my winter build project, not a monster like some. I wanted a plane that looked and flew like a Magnatilla but powered by a 30cc petrol, so I got a large sheet of paper and drew my own design. I made sure all the wood lengths were 36in or less to use standard size balsa etc. so the wings came out at 40inch including tips with the profile copied from my Taxi 2400. The fuselage construction is similar to the Magnatilla except the whole of the upper front section is removable for ease of access. The 2 piece wing is joined with a joiner from Falcon Aviation. After drawing all the sections everything was cut out on my bandsaw. First part of the build shown below.
Re: Bigtilla
Posted: February 15th, 2011, 9:57 am
by Barrie King
A couple more shots
Re: Bigtilla
Posted: February 15th, 2011, 12:30 pm
by Denis Brown
Looks pretty good. If you lost your glasses they are on the bench
Re: Bigtilla
Posted: February 15th, 2011, 8:23 pm
looks good, good idea about a 2 piece wing, i feel flair would have sold a shedload more hannibals, if they had thought it out better, with a 2 piece, and a detachable tail
Re: Bigtilla
Posted: February 16th, 2011, 12:23 pm
by Ken Bones
That looks likes nice, should be a whole load of fun.
Bonzey
Re: Bigtilla
Posted: February 16th, 2011, 6:30 pm
by Barrie King
Yes Alan, I looked at the Hanibal but the wing put me off. A couple more pics now covered.
Re: Bigtilla
Posted: February 16th, 2011, 9:31 pm
by Mike Booth
A thing of beauty, must send Dudley Paterson the link.
Re: Bigtilla
Posted: February 16th, 2011, 10:32 pm
by Barrie King
Here is a picture of the suspension, you won't find this in a Flair kit!
Re: Bigtilla
Posted: February 16th, 2011, 11:08 pm
by Mike Booth
A true aeronautical carriage, ideal camera ship.
Re: Bigtilla
Posted: February 17th, 2011, 9:35 am
by Barrie King
Also made a choke that is easily operated from outside the cowl. The gun by the way was made from 1 1/2 in waste pipe and balsa block with a TV aerial plug for the muzzle inside which is a high brightness LED driven by a flasher unit from Maplin. ( I was bored one evening! )
Re: Bigtilla
Posted: February 17th, 2011, 9:49 am
by stuart knowles 1611
and modelled on a 6" naval gun I see, should be effective
stu k
Re: Bigtilla
Posted: February 17th, 2011, 6:46 pm
by stewart clifford
You'll have someones eye out with that gun
Re: Bigtilla
Posted: February 17th, 2011, 8:17 pm
by Barrie King
All ready to go looking for frigates and destroyers!
Re: Bigtilla
Posted: February 17th, 2011, 9:31 pm
by Ken Bones
Have you really built this in four days?
Bonzey
Re: Bigtilla
Posted: February 17th, 2011, 9:46 pm
by Mike Booth
Surely this needs to be an RTF kit.
Re: Bigtilla
Posted: February 17th, 2011, 11:12 pm
by Barrie King
No Ken took me about 3 weeks to build, from drawing to completion, but only just got round to posting it up. I am now busy finishing off an 11ft lanc for a clubmate.
Re: Bigtilla
Posted: November 12th, 2012, 4:54 pm
by Barrie King
I never thought a 30cc 2 stoke suited this plane so I bought a brand new boxed Honda 31cc 4 stroke for £140. When it arrived it weighed in at 9 1/2 lbs so I set about it with a vengence to remove all unnecessary bits. I got it to about 5 lbs with its original flywheel mag ignition and it flew the Bigtilla quite well for a year. i then decided to change over to electronic ignition and found it would loose another 1 1/2 lbs it has now had 1 test flight on the new system with no problems. Next i may dispose of the sump and oil system and run it on a 2 stroke mix, has anyone ever tried this?
Re: Bigtilla
Posted: December 29th, 2012, 4:49 pm
by Barrie King
Decided on another engine change for the Bigtilla, just taken delivery of one of the new NGH 38 four stokes, this should give a bit more grunt than the Honda. Has anyone else tried one of these?
Re: Bigtilla
Posted: January 15th, 2023, 2:55 pm
by Michael Boulton
Hi I read in one of the wanted posts that this may be for sale if it is could you please let me know how much you want for it Mick
Re: Bigtilla
Posted: January 15th, 2023, 5:24 pm
by williamjrmacleod
Sent you a pm barrie. Bill
