Page 1 of 3
monocoupe 90 clipped wing 26cc
Posted: June 8th, 2014, 7:40 pm
by richard armstrong
hi all
brought this clipped wing MC from rich at falcon in the process fo finishing it as it was 85% complete
what glues do you used to glue wind shields in with
and advice on fitting, it as it has to sit round a curve nose,
Re: 110 clipped wing monocoupe 35cc
Posted: June 9th, 2014, 7:07 am
cut a stiff card template, and i use pacer canopy glue, clean hands, and a wet cloth to wipe away surplus
Posted: June 9th, 2014, 7:16 am
Alan Cantwell 1131 wrote:cut a stiff card template, and i use pacer canopy glue, clean hands, and a wet cloth to wipe away surplus
thanks alan
i pick ups some pacer glue this week
never thought about using card to get a good fit DOH!
Posted: June 10th, 2014, 4:10 pm
just wondering how to calculate the weight and engine size
7ft wing AUW with no electronics or tank 5.5 kg estimated!
i was looking into a 35 cc
anyone know of a online calcultor to give me the engine size?
Posted: June 10th, 2014, 4:58 pm
no, but i will give you years of experiance, 26 ccm max, unless you want to be prop hanging it :roll:
no, but i will give you years of experiance, 26 cc max, unless you want to be prop hanging it :roll:
Posted: June 10th, 2014, 5:42 pm
Alan Cantwell 1131 wrote:no, but i will give you years of experiance, 26 cc max, unless you want to be prop hanging it :roll:
thanks alan
26cc - 30cc not looking to prop hang but am looking for a little extra umph, to get me out of the sh*tt**
i have look at the dle 30cc, and dla 30cc, i need to do a bit more investigation, but open to suggestion on make, my max budget is £225, at present, but every penny saved is more for another, airframe
unless i can find a 30cc unused or used
Posted: June 10th, 2014, 5:53 pm
to much oomph, as you put it, could well put you in the crap you are trying to get out of, but still, your plane, have fun, you can always throttle back
Posted: June 10th, 2014, 6:21 pm
Alan Cantwell 1131 wrote:to much oomph, as you put it, could well put you in the crap you are trying to get out of, but still, your plane, have fun, you can always throttle back
mis read this sorry
Posted: June 11th, 2014, 7:42 am
by paul hughes
Richard, Alan has been building and flying models for a very long time ( over 40 years) and has owned just about every commercial kit or model that has been produced. If he says 26cc max then thats what it is!
Why do you ask for advise and then tell people the advise is wrong! kind people are trying to help you.
As for cost, the smaller engine will be cheaper to buy and use less fuel, another plus is props are cheaper for smaller engines. Also the model will be lighter and threrefore easier to fly and land. The model you have is designed for a .91 2 stroke glow engine, which is about 15cc, so a 26cc petrol will be fine and about the right weight.
With the GeeBee model Ys we found that a 25cc powered model is no quicker than a 38cc powered plane, this is beause the airframe has so much drag it has a terminal speed and only a massive engine will pull it any quicker. Your monocoupe is the same span and although a high wing rather than low has a similar amount of drag.
In Short listen to Alan!
Posted: June 11th, 2014, 5:09 pm
now i just feel old :D
Posted: June 11th, 2014, 7:50 pm
by Phil Clark
The DLA - BLE 30's are potent little engines..........way above what is recommended for this airframe. Fitting this much power is likely to cause you more problems than it solves, especially as a relatively inexperienced pilot (no disrespect). The saying 'you can never have too much power' isn't true to all airframe types. In a slow flying, lightly loaded type like this, it's definitely not what you want. This uses it's wings to fly not it's engine.
The 30's are also pretty light weight engines........you have an airframe with a VERY short nose and quite a long bulky rear end.......so why fit a light engine and run the risk of either having to shoe horn batteries further up front (where they probably weren't designed to go), or add extra nose weight.
This model is crying out for a simple, reliable Zenoah 26. It's more than enough power & being a little heavier than the 30's, it's 'useful' weight rather than a light engine + ballast. It's side induction, side exhaust so will fit in the radial cowl easily. Everything stacks up in the Zenoah's favour. Add 20 quid to your budget & buy one......
Posted: June 11th, 2014, 9:24 pm
Phil Clark wrote:The DLA - BLE 30's are potent little engines..........way above what is recommended for this airframe. Fitting this much power is likely to cause you more problems than it solves, especially as a relatively inexperienced pilot (no disrespect). The saying 'you can never have too much power' isn't true to all airframe types. In a slow flying, lightly loaded type like this, it's definitely not what you want. This uses it's wings to fly not it's engine.
thanks phil for the constructive advice i will take it on board,
Posted: June 11th, 2014, 9:36 pm
paul hughes wrote:Richard, Alan has been building and flying models for a very long time ( over 40 years) and has owned just about every commercial kit or model that has been produced. If he says 26cc max then thats what it is!
i know alan been at this game for more years than ive been alive, and i respect his advice, and your advice all valid
on the note i will look into a z26 but partly have not looked at z's is 2 reasons is the side carb as i was looking an in line carb unless there a new version out? cost as it was as out side my reach , but that said there are some deals to have at the mo
i need to think????
Posted: June 11th, 2014, 10:13 pm
more years than you have been alivem there goes that feeling old again :(
Posted: June 15th, 2014, 7:57 pm
Alan Cantwell 1131 wrote:more years than you have been alivem there goes that feeling old again :(
Alan, any of these fit for purpose for the coope mate
found these on ebay just wondering if it would be enough power, thought of taking a look at the second market first to see what out there,
http://www.ebay.co.uk/itm/Mackay-24cc-M ... 2a3e33f349
http://www.ebay.co.uk/itm/181425245978? ... 1423.l2649
http://www.ebay.co.uk/itm/26cc-petrol-e ... 3f3809929f
advice very welcomed
Posted: June 15th, 2014, 9:51 pm
2of the links dont work, the 26 would be ok, but would need a huge chunk out of the firewall, ive just got back from weston park, were i was running the swapmeet, i saw about 4zenoah 23s not one was more than £50 quid, you should have gone
Posted: June 15th, 2014, 10:41 pm
Alan Cantwell 1131 wrote:2of the links dont work, the 26 would be ok, but would need a huge chunk out of the firewall, ive just got back from weston park, were i was running the swapmeet, i saw about 4zenoah 23s not one was more than £50 quid, you should have gone
wish i could have gone but finances dictated otherwise,
50 quit, bummer, if had known i would have ask for one to be pickup,
this ons is on the bay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1523091103
but wants to much for it
Posted: June 15th, 2014, 10:44 pm
Posted: June 15th, 2014, 10:48 pm
is there a swap meet at cosford?
not sure when the next show is before cosford where there is a swapmeet
