1/3 scale Spitfire
Posted: June 10th, 2014, 8:32 pm
by david clarke
I have for the last few weeks been making good a built up fuselage to have a mold taken from it,the model a 1/3 scale Spitfire it is the most impressively detailed model I have seen.It was built from original factory drawings and it is faultless the shape is perfect,it spans 148" and as I speek the mold for the fus is complete and the first fuselage is being laid up.The estimated weight of the fus is between 5 & 6 kg,once I have the fus back the wing will be made good and a mold taken from that,a set of retracts and a spinner will also be available.If there is enough intrest in the model a kit could and will be produced,if you require further info please call Rob on 07864811219.
Cheers,Dave.
