Page 1 of 6
Mick Reeves 25% Spitfire Build
Posted: April 11th, 2016, 12:07 pm
by Rob Crawford
Hi all
My name is Rob Crawford and i have become a member of LMA,i'm from N/Ireland and have been into RC from the age of ten (27 years, yikes, is it that long)
I am getting back into large models after a 10 year break and have registered a MR 1/4 scale Spit in the over 20kg scheme.
The inspector designated is Ian Robb whom I know from RC years back at the Nutts Corner club.
Glad to be a member of this well organised association and look forward to meeting you all.
Rob.
- Kolm Il 135
- forum 3.jpg (77.06 KiB) Viewed 67140 times
- kolm IL 135
- S2010004.JPG (155.1 KiB) Viewed 67140 times
- Wing
- forum pic.jpg (170.11 KiB) Viewed 67138 times
Re: Mick Reeves 25% Spitfire Build
Posted: April 11th, 2016, 12:38 pm
by Rob Crawford
Posted: April 12th, 2016, 7:47 am
by John Greenfield
Hi Rob
Neat building, well done. I notice you have fitted an RDS system for the ailerons but I don't recognise the manufacturer of it from the photos. Can you supply details or did you make it yourself.
Posted: April 12th, 2016, 3:43 pm
by Rob Crawford
Hi John and thanks!
Yes i use this on mostly everything simply because it has zero slop and yes i did make it myself.
Some pics
Posted: April 12th, 2016, 5:05 pm
by Wayne Cox
Hi Rob,
Great looking build so far.
Also watched your videos on YouTube motor sounds very nice.
Keep the photos coming, have you decided on markings yet.
Wayne
Posted: April 12th, 2016, 5:15 pm
by Rob Crawford
Thanks Wayne
The kit as you probably know is based on MK 9 MH434 but i am going to try to make it look like EP 120 hence the absence of wing tips it's clipped!
What a beauty!
Posted: April 12th, 2016, 5:19 pm
by Rob Crawford
I'm on the lookout for the 3 branch exhausts for 1/4 scale or even molds will do, i have the MK9 pipes but EP 120 doesn't have those Lol attention to detail!
Posted: April 13th, 2016, 9:14 am
by stewart clifford
I think Phil Clarke sells them.
Posted: April 13th, 2016, 6:11 pm
by Rob Crawford
Thanks Stewart
I'll be getting the paint of Phil, never really looked on his site but i'll get in touch and see if he can help.
Posted: April 15th, 2016, 8:58 am
by John Greenfield
Rob Crawford wrote:Hi John and thanks!
Some pics
Thanks for the reply Rob.
Can I ask what you use on the inside faces of the slot in the control surfaces that the wire runs against and what you use for a bearing in the wing trailing edge.
Posted: April 17th, 2016, 12:28 am
by Rob Crawford
No worries John i'm glad it's of interest.
The slot for the wire is a plywood box lined on the inside with the Mick reeves proskin (it's hard stuff) you need to get this perfect, it's one of the most critical parts of the setup,not to tight and the gap must be totally even.
you can achieve a good fit by cutting 2 shorter lengths of same swg wire and placing them at each side of the plywood box before bonding the sides on.
The bearing is simply the outer sheath of a control snake hysoled into a 6mm plywood sheer web, a simple set-up really but the slop is zero and i don't think you need to use such high torque servos with it.
Posted: June 23rd, 2016, 6:13 pm
by Wayne Cox
Hi Rob,
Hope the build is doing well, been keeping an eye out on your build.
Waiting for some updates lol.
Wayne
Posted: July 11th, 2016, 5:47 pm
by Rob Crawford
Posted: July 11th, 2016, 6:02 pm
by Rob Crawford
The windscreen must be flush with the frame.
- flush windscreen.JPG (64.63 KiB) Viewed 66098 times
Posted: July 11th, 2016, 6:17 pm
by Rob Crawford
Posted: July 11th, 2016, 6:26 pm
by Rob Crawford
Posted: July 11th, 2016, 8:28 pm
by Bob Thompson1894
wow......love the canopy!
Posted: July 11th, 2016, 9:16 pm
by Rob Crawford
Thanks Bob that means a lot.
When i forgo being social for months on end i can loose enthusiasm.
Not even getting much flying done with the weather,it's been a poor summer altogether this year where i am so i thought i'd get stuck in and do a bit to the spit.
