Ian,
I tried emailing you but it didn't work. I'm happy to have a crack at a
simple version of the Boulton-Paul Mk IId turret suitable for your "Defiants", but need some information from you, see attached image. I'm now waiting for parts here, so if you were able to give me these dimensions, and the desired scale of your Defiant(s) I can draw something up. The turret will likely be free to rotate in elevation, but not motorised or similar to do so, and of course you can figure out traverse. It will probably cease at the same level as the lower cupola - chest high for the gunner. You can then decide if you want the basic drawing of the turret and get it printed yourself. I estimate that if you did the printing commercially, the costs would likely be north of £300. The guns I'd print for you, as I'm now hoping to produce kits eventually for the FN5, FN5a, FN50 and FN20 turrets, so obviously am not comfortable with circulating files of stuff that I hope to sell in due course. However, as a one-off, I'm happy to help with your Defiants in this way.
Regarding FN5's, I have some 1:4.5 scale parts that are surplus here, most of the spent-cases chutes, including the V profile lower section, suitable for a tail-turret FN5, and two hydraulic accumulators (only 1 needed per FN5), the top of the gun-sight and a few other odds and sods. You're welcome to these if you can use them, free and
gratis. I've yet to build my FN5's, so would rather not be producing parts for these yet other than for my own use, until I'm more certain everything assembles properly, however, if you wanted, for example a pair of Brownings made at 1:4.5, then we could come to terms on that.
Which brings me onto my next point. I designed mine, initially, really just for my own use and as an exercise to see if I could. I think most people, if they'd want them at all, will likely only want particular components 3d-printed, to whit, those shapes that would be under some scrutiny, and which are otherwise very difficult to make. In the case of the FN5, this would mean the Brownings, the entirety of the cradle that carries the guns, the chordal stiffeners, and the ammunition chutes and the hand-grips, plus the "stack" of hydraulic valves atop the central console, between the gunner's knees. Provided that the turret was not being motorised in the manner mine will be - I hope! - these parts would really be all you need, the rest can largely be made from sheet materials, be it balsa, plastic etc. That will likely strike a more reasonable balance between cost and effect, if you see what I mean.
If it helps, here's how I went about drawing the FN5. I found illustrations of the turret from overhead, and from one side, ported these into the CAD package as "canvases", then gradually worked out how it all fitted together referencing photographs, using these illustrations as initial plots for relative dimensions and positions. Hence the huge number of revisions! It's a very long job though.
I won't do
anything on the BP turret unless I hear from you, let me know if you'd like the spare FN5 bits, or if you'd like Brownings or other FN5 bits made, likewise, being mindful that I'm yet to assemble mine. I shan't be in the last offended if you elect to draw it yourself!
- Dimensions (and your Defiant scale) that I'd need.
- Type a measurements.jpg (219.28 KiB) Viewed 16967 times
- How I went about the intial drawing
- canvases.jpg (170.28 KiB) Viewed 16967 times
PS, the "type A" B-P turret is pretty similar, to the Mk IID, if there are differences, I can't spot them. This was the best picture I could find to use.
