I have fnished the fus paintwork now. I have to say that following Phil Clarkes post much earlier in this thread re how to paint with masking has worked really well.
When I sprayed the white first I did it to just past where the red started so that there was overlap but not too much extra paint put on. I didn't bother masking for the white.
For the red pattern I have maske dusing 3mm fineline tape and used cardboard templates for the curves. There are no less than 7 different radii used in this pattern so I drew scale shapes in autocad and printed them to card. I have followed the cardboard carefully with the 3mm fineline. I then found that a good way of making sure those curves stay stuckk is to run 5mm fineline tape around the curve on top of the 3mm to hold it down better. It is then easier to use masking tape to cover the rest of the white.
Once everything is masked I have then used an Iwata spray gun with a 0.6mm needle and a circular spray pattern to spray white on all of the fineline edges, sealing the edge down. I have then used a 0.9mm neddle spraygun with a fan spray to apply the red. Then to finish, all the tape is carefully peeled off before the paint has gone hard.
So far I have just one small tiny bit of red got under the tape - where the 2 fus halves join!
Getting ready to paint the underside...
- IMG_3450.JPG (45.93 KiB) Viewed 17011 times
Fus done....
- IMG_3451.JPG (50.85 KiB) Viewed 17011 times
