Mick Reeves 1/4 Mk IX Spitfire
Re: Mick Reeves 1/4 Mk IX Spitfire
Postby stewart clifford » December 16th, 2012, 11:27 am
Completed roundal and serial number.
sun1 005.JPG (84.46 KiB) Viewed 18984 times
andywynn
Postby andywynn » December 16th, 2012, 8:26 pm
I must admit i think these spraying pics are the best ive seen ;)
RAY PETERS
Postby RAY PETERS » December 16th, 2012, 9:36 pm
Stewart ,any chance of showing your paint masks on the OTHER side.??? Very interesting. :D :lol:
Postby stewart clifford » January 14th, 2013, 2:19 pm
In no particular order here's some more pics of various stages of the build. It's just a case now of working through a shortish list of final jobs. Most are simple but the inner flaps which are part of the fuselage moulding a proving to be a bit tricky to hinge, this is due to the curve in them, tried a few ways so far an not really getting anywhere.
Spitfire 003.JPG (70.8 KiB) Viewed 18821 times
Spitfire 006.JPG (60.75 KiB) Viewed 18821 times
Spitfire 007.JPG (56.45 KiB) Viewed 18821 times
Spitfire 024.JPG (86.46 KiB) Viewed 18821 times
little man tries out his office
Spitfire 033.JPG (81.43 KiB) Viewed 18821 times
Postby stewart clifford » January 14th, 2013, 2:22 pm
More, inc a very nice set of cannons made by Mark "Stamper" Houghton
Spitfire 035.JPG (81.22 KiB) Viewed 18821 times
Spitfire 036.JPG (74.81 KiB) Viewed 18821 times
Spitfire 038.JPG (97.99 KiB) Viewed 18821 times
Spitfire 045.JPG (135.44 KiB) Viewed 18821 times
Spitfire 047.JPG (119.21 KiB) Viewed 18821 times
Richard scarbrough
Postby Richard scarbrough » January 15th, 2013, 7:45 pm
Like the calender hanging on wall!!!!!!
Want's that funny thing in the front :o
Richard.
andywynn
Postby andywynn » January 16th, 2013, 10:01 am
Richard scarbrough wrote:Like the calender hanging on wall!!!!!!
Richard.
Recurring theme here i think Stewart :) Spits looking good as well :lol:
Postby stewart clifford » January 16th, 2013, 10:24 am
Two more Spitfires, a Bf109E and a Mustang in the que for painting, better get down the newsagents
Postby stewart clifford » March 28th, 2013, 9:45 am
As you can see, the green on the wing for some weird reason turned out lighter than that on the fuselage. So yesterday I reprinted the green on the wings, today I should be able to put on the satin clear cote then finish the fit out. It's looking like its not going to need very little if any lead I'm the nose due to the 7 batteries which will required to operate it.
Postby stewart clifford » April 4th, 2013, 3:43 pm
MH418 finished and left here today.
apr13 026.JPG (127.03 KiB) Viewed 18308 times
apr13 029.JPG (65.69 KiB) Viewed 18308 times
apr13 027.JPG (120.88 KiB) Viewed 18308 times
chris willis
Postby chris willis » April 4th, 2013, 5:44 pm
Looking good Fighter Boy
Postby stewart clifford » April 4th, 2013, 6:13 pm
Since the house move I've had to finish the Spitfire in the kitchen, now it's gone Amy thinks she'll get her kitchen back. :lol: :lol: :lol: :lol:
apr13 023.JPG (68.55 KiB) Viewed 18289 times
Mike Booth
Postby Mike Booth » April 4th, 2013, 7:59 pm
Excellent Chief, excellent. Spitfire production in full swing.
Does Amo-unit know that enamel paint dust will curdle cupcakes?
Postby stewart clifford » April 24th, 2013, 8:13 am
Come on David, hope your getting ready to test fly on Friday at Rougham.
Rob Crawford
Postby Rob Crawford » February 10th, 2017, 11:55 pm
Looks great!
How did you get a good key on the fuselage and still keep all that detail?
Etch primer?
cheers
Rob
Postby stewart clifford » February 11th, 2017, 8:06 pm
Hi Rob
If I'm totally honest, I can't really remember. I know I didn't lose the detail and I used just normal cellulose grey primer then warbird colours for the top coat. I did key it up, probably with a fine wet and dry paper, because of a previous bad experience with pin holes I was more mindful of rubbing away the surface and causing pin holes than I was concerned about losing detail. Whatever I did worked, no pin holes and the paint didn't come off.
Cheers.
Postby Phil Clark » February 12th, 2017, 12:04 am
You'll loose detail in the moulding if you use wet & dry.........better approach with any detailed composite component is a fine Scotch Brite type pad (mine are ultra fine from MIRKA). Use these pads to loose the gloss from the surface & key it ready for etch primer All these do is key the surface rather than cutting into a rubbing away any detail. After this, I use a 1K etch primer from Lesanol.......it's lime green in colour & has very poor coverage, but 1 light coat is all is required. I've never had any paint adhesion issues using these products over the past 10yrs or so.......
Rob Crawford
Postby Rob Crawford » February 12th, 2017, 6:52 pm
Cheers guys for the help.
I have been recommended the scotch brite etch primer many times so i think that's what i'll do,the tried and tested way.
I'll have a look for the mirka ultra fine,i use their products all the time and they're top notch.
If i can't get the Lesanol will any etch primer be a substitute?
Is that a carf spit Phil?
Postby Phil Clark » February 12th, 2017, 9:22 pm
Yes....it's a CompARF I did for a client 4-5 yrs ago.
If you struggle getting the Lesanol, let me know & I'll get you a tin.
Rob Crawford
Postby Rob Crawford » February 13th, 2017, 11:44 pm
cheers Phil
Much appreciated.
That spit looks great!
Users browsing this forum: No registered users and 59 guests
