Onboard Charging
John Evans
Onboard Charging
Postby John Evans » January 30th, 2013, 7:55 pm
Hi
We purchased a Eco fan for our multiburner stove. These are powered by a peltier element. The question is, would it be possible to use the element if it were affixed to a 2 stroke silencer, with a suitable heatsink to power a onboard charging system whilst in flight
Hope for some replys
John 1915
peltier element.jpg (3.91 KiB) Viewed 6387 times
Re: Onboard Charging
Postby Rob Buckley » January 30th, 2013, 11:00 pm
John, anything's possible it just might not be easy!
What kind of batteries would you want to charge? Lithium's would be a bit tricky to manage, but NiMh or lead acid would be easier to make work.
Although, unless you were thinking of going for an Atlantic crossing, it'd be easier to use a charger between flights. You'd know the batteries were fully charged & how much had been put into them, rather than hoping the onboard system was still working.
John Evans
Postby John Evans » January 31st, 2013, 9:41 am
Hi Rob
Was thinking of NiMH. This would of course have some sort of indicator in a position to show that the system is charging. You would as a matter of course check the battery status prior to each flight.
Thanks for the reply
John 1915
Glenn Masters
Postby Glenn Masters » January 31st, 2013, 2:46 pm
Go 'n give your caravan a wash if you've nowt to do mate !! ha ha
John Evans
Postby John Evans » January 31st, 2013, 6:40 pm
Hi Glen
I assume by that answer, you cannot answer the original question.
So have you got the two beeches ready Ha Ha
John1915 soc
Dave Hayfield
Postby Dave Hayfield » February 1st, 2013, 1:03 pm
Hi John, if you abandon the on board charging idea you can always reverse the process. If you apply a voltage to the Peltier cell it will lower it's temperature, strap it to the cylinder head and increase the cooling for the engine. Well, just a suggestion !!!
Thanet Model Flying Club
LMA 520
paul hughes
Postby paul hughes » February 1st, 2013, 2:47 pm
why not go one further, have a Peltier cell in the exhaust suppling a Peltier cell on the cylinder head?
Postby Bob Thompson1894 » February 1st, 2013, 3:15 pm
I just charge up the night before.......
