Brison 90 /95cc info needed
Shaun Garrity
Postby Shaun Garrity » August 17th, 2013, 4:30 pm
Hi can anybody help ..
I have just acquired a Brison ( 90/95cc ) with electronic ignition using the older mechanical advance and retard system..
I know it's an older engine but this example is little used....
I'm guessing it will turn a 28" prop, unsure of optimum pitch for a 1/3rd scale Fokker D7...
Has anybody got a set of instructions they could email me please.
Also has anybody modified the ignition on one using a Rexel unit with auto advance / retard.. Your advice would be appreciated
Shaun
DAVE BAILEY
Re: Brison 90 /95 cc info needed
Postby DAVE BAILEY » August 17th, 2013, 5:40 pm
Hi Shaun
Brison recommend a 26/10 giving 40lbs thrust This is for the 95 cc engine
DAVE.B
Shaun Garrity
Re: Brison 90 /95cc info needed
Postby Shaun Garrity » August 17th, 2013, 5:54 pm
Thanks Dave,
do you know if they made a 90cc version or only a 95cc one?
Still would be interested in the instructions if anybody has some available..
Shaun
Postby Alan Cantwell 1131 » August 17th, 2013, 8:02 pm
i downloaded these a while ago, i have the same engine, not used it in anger yet though, hope it helps
http://www.brisonrcengines.com/bri%20owners.pdf
http://www.brisonrcengines.com/bri4u.htm
Shaun Garrity
Postby Shaun Garrity » August 17th, 2013, 8:45 pm
Cheers Al.
