John Greenfield wrote:Paul
On all the Greenleys and Lowleys I have built including the SDD Greenley 100cc version I use the great planes CA hinges and have never had a failure. They are easy to install by just making a slot with a knife and sliding them in dry. Push the control surface up against the trailing edge and after making sure you have sufficient control surface movement wick in some fresh thin cyno one drop at a time from the top and bottom. Keep adding one drop at a time until no more is absorbed. Finally pin the hinge with a normal dress makers pin pushed in from the underside and put a drop on thin cyno on the end of the pin to stop it falling out.
Elevators and rudder should have 5 hinges each and the ailerons 6 equally spaced out along the surface. Do make sure that one hinge is at the point where the control horn is.
Greenley Designer.
