sean smith wrote:I assume that this is not your first model? The air frame can take the engine if you feel you can handle the model.
Sean.
sean smith wrote:Richard
The question is which Greenley is it? Standard, SD (i assume its not the SDD). As John has said keep the tail as light as you can i had to add weight to the nose balance my standard Greenley.
(sorry John forgot there was three versions of the model)
Sean.
John Greenfield wrote:The flaps on the SD Greenley wing give an added dimension to its flying but it is equally happy without them if you do not want the complication of building them in.
Full details and free downloads of all the Greenley and Ampley models can be found on the Ghost Squadron website at http://www.ghostsquadron.co.uk.
Greenley designer.
sean smith wrote:Richard,
There is a plan for a built up wing for the Greenley which shows the flaps or you can go with foam wings, i got mine cut by Bill at http://www.billkits.com He cut the wings for my Greenley and Lowley.
Sean.
The built up wing is lighter than the foam one and also much easier to make 2 piece as all the holes for the joiner tube are already shown on the plan. The joiner tube is a standard item from SLEC.
Why would you want to change the undercarriage
or lighten the model ?
The undercarriage has been designed to integrate into the model and produce a light and strong solution. To just bolt an ali or carbon unit onto the bottom will not produce a strong structure and is likely to pull out of the bottom of the model in a less than perfect landing unless you do significant beefing up of the fuz and mounting plate which seems to go against your wish to make it lighter. Unless you are going to mould or fold your own U/C you will also find that the wheels are too far forward if you bolt a standard U/C to the model but I am sure if you are capable of making decisions to change the design you will understand how not having the wheels in the right place on any model will affect the ground handling and landings.
Users browsing this forum: No registered users and 120 guests
