monocoupe 90 clipped wing 26cc
Re: 110 clipped wing monocoupe 35cc
Postby Alan Cantwell 1131 » June 16th, 2014, 7:38 am
3 engines i would use in this, MVVS 160, with pitts silencer, or a zenoha 23 or 26 both should fit the cowl, both will power it well, the zenoah 23 can be picked up at right money, as can the MVVS, i would not cosider any pther motor bought 2nd hand, buy it off a trusted LMA member you can have diaologie with, buy off ebay is a chance, with no back up, buy off here, and problems can be sorted, now stop MESSING and take the damned advice
richard armstrong
Postby richard armstrong » June 16th, 2014, 11:28 am
Alan Cantwell 1131 wrote: now stop MESSING and take the damned advice
why do think alan i asking for advice, i don't want to just jump in and screw everything up, hence my caution, i have done that in the past and got burnt very badly,
i have posted on hear for a 26cc zonoha but not luck so far,
so if i can get a Z26cc then i would jum at it but if cannot then i will look at an alternative
by the way the z26cc is 1.3 kg all in , the HK 26 cc , is 1.8kg all in, that was a bit of a surprise,
i want to get the coope ready for testing @ cosford, out of hrs if possible, but having hard time finding a used Z26cc, but that said i might have to cough up on a new one (ouch), but would like to ry the used market first
do you hve a 26cc you ant to part with ? or know anyone
sean smith
Postby sean smith » June 18th, 2014, 2:31 pm
Found this on the BMFA Classified site:
http://www.bmfaclassifieds.co.uk/detail.php?id=161968
richard armstrong
Postby richard armstrong » June 18th, 2014, 5:26 pm
sean smith wrote:Found this on the BMFA Classified site:
thanks seam on it
richard armstrong
Postby richard armstrong » June 20th, 2014, 4:16 pm
alan
i have chance of a 30cc see link
Specifications:
* Displacement : 30.5cc.
* Output Power : 3.7HP/8500rpm.
* Idle Speed : 1600rpm/min.
* Static Thrust : 8.5KG Pulling Force/ 100 meters Altitude.
* Static Thrust : 7.5KG Pulling Force/1800 meters Altitude.
* The specification of the aircraft propeller : 18 x 10; 18 x 8; 19 x 8; 20 x 8.
* The type of the sparking plug : NGK CM6.
* Exhaust Amount : 20cm3.
* Diameter stroke : 30.5mm × 30mm.
* Ratio of compressio : 7.6:1.
* Ratio of lubricating capacity : 30:1.
* Fuel : 2C Regular Gasoline mixed 30:1(Mineral based for breakin, synthetic thereafter).
* Ignition Battery : 4.8 - 6.0v (max) ≥ 1200mah.
* Types of the Spark Plug : NGK CM6 or quivalent.
* Plug Gap : 0.018" to 0.020.
* Installation Torque : 7 to 8 ft-lbs.
* Main engine weight : 0.91kg.
* Exhaust pipe weight : 0.06kg.
* Ignition equipment weight : 0.12kg.
would this be too much for the coop
http://www.ebay.co.uk/itm/agm-30cc-petr ... 4d1f1a7b75
or wait it out
richard armstrong
Postby richard armstrong » June 20th, 2014, 4:21 pm
richard armstrong
Postby richard armstrong » June 21st, 2014, 12:53 pm
Postby Alan Cantwell 1131 » June 21st, 2014, 5:33 pm
i would buy the zenoah 26 over the roto, just BUY one of them
richard armstrong
Re: 110 clipped wing monocoupe 25cc
Postby richard armstrong » June 28th, 2014, 1:10 pm
brought 2 26cc in the end
1 roto 25cc
1 turnagy 26cc
decided to fit the 25cc roto, due to the extra weight, but need advice on how to fit i, because eh choke is the lock on, throttle off type i know i going to have to cut a hole in the firewall
but before i jump in is there any local be able to pop over an give advice please
i am nottinghamshire
richard armstrong
Postby richard armstrong » June 28th, 2014, 1:53 pm
i also need help drilling the prop
richard armstrong
Postby richard armstrong » June 29th, 2014, 10:42 pm
Help
i have a issue,
i brought 2 x 26c engined
the roto i heavier and need no lead in the nose but it don't fit in the cowl without cutting it and tweak in the front end of the cowl,
the turnagy 26cc is lighter and needs no alteration to the cowl and will require a chunk of lead
which to use?
advice please
Postby Alan Cantwell 1131 » June 30th, 2014, 6:27 am
non of the above, or the one that fits, but the batteries behind the firewall, and just ballastbthe thing
Barrie King
Postby Barrie King » June 30th, 2014, 3:26 pm
Hi Richard,
I am in Retford, and a few of us here fly 26 and 30cc models, so we should be able to meet up to sort you out.
Barrie
richard armstrong
Postby richard armstrong » June 30th, 2014, 3:27 pm
Barrie King wrote:Hi Richard,
Barrie
cool mate
want to pop over i cover your fuel
Barrie King
Postby Barrie King » June 30th, 2014, 3:33 pm
Pm me your address and Post Code and mobile and will arrange a visit, Wednesday morning could be best for me.
richard armstrong
Postby richard armstrong » June 30th, 2014, 6:21 pm
Barrie King wrote:Pm me your address and Post Code and mobile and will arrange a visit, Wednesday morning could be best for me.
thats great
thanks i can spare an 1r so with advice i work from home
pm sent
richard armstrong
Postby richard armstrong » June 30th, 2014, 6:54 pm
can anyone help with a little engineering task
the stand off's that came with 26cc engine that i finally decided to use are approx 30mm to long and need to be cut down, re-drilled and re-tapped i can re-tapped them but don't have a lathe to drill and face off can anyone help?
unless there is off the shelf standoff's @ 45 - 50mm i can buy
who is local to me -ish
can post
Postby Alan Cantwell 1131 » June 30th, 2014, 7:58 pm
i am mown out at the moment with works work, but if you dont get sorted, i will do them cheap,
Postby Rob Buckley » June 30th, 2014, 8:10 pm
60mm machine screws & a few ply discs are cheap. As are thick penny washers if you need the noseweight anyway.
Barrie King
Postby Barrie King » June 30th, 2014, 8:41 pm
Richard it says your pm was removed by you before it was delivered, strange :?:
Barrie
Users browsing this forum: No registered users and 99 guests
