Postby MalcolmDouglasPorter » December 19th, 2014, 5:19 pm
I had an absolutely mega day today! Thanks to the patterns I made the other day, I made all the remaining front end frames. As you can see from the picture, I had to have a play, and this playing is a good exercise as it has shown up all the small errors. There are lots of small errors to sort out! So I have to fiddle, fettle, adjust and mess about to get it all to fit properly. There are a couple of very small cock ups to eradicate, but nothing to shed a tear over. It also show quite clearly that some of the frames are a little out of shape. Once I have all the joints fitting properly, I will need to set about fettling the shapes to conform the the diminishing compound curves, actually very easy to determine now that the frames can be assembled. I hope that I do not have to re-make any frames, but if I do, then I shall do this in the knowledge that it will be correct in the end! This front half part of the model measures 4' 9". The balsa nose cone will make it very close to 5 feet!
It is amazing the difference between what I produced yesterday and the work I did today. The time is taken up in measuring and marking out, and that was absorbed into the pattern making. Whilst I eradicated some possible cock ups in the patterns, there are still a few that got through the net. These cock ups can be got rid of either by remaking the part or a bit of artistic adjustment? It will be all right on the night, as they say? That "night" may well be after Christmas?
I have lots of stuff to do, starting tomorrow, so if I do not post again this side of the festivities, may I take this opportunity to wish all my fellow modellers a very happy Christmas. You should all remain perfectly sober, and do not eat cake!
- Front frames at stage one.
- PC190001.JPG (175.07 KiB) Viewed 15476 times
- Finished frames and their now redundant patterns.
- PC190002.JPG (162.66 KiB) Viewed 15476 times
- The inevitable dry run!
- PC190005.JPG (191.88 KiB) Viewed 15476 times
