Bob Thompson1894 wrote:As Ian. Also, have you undersealed the ply underneath? Also are you bolting the ply to the chassis? If not it will shake loose, coach bolts are the best. (ex caravan builder)
ian redshaw wrote:What are you doing for insulation and damp proofing, anything? Models don't tend to fare too well stored in uninsulated trailers. Or is the trailer to be stored inside?
Ian.
Bob Thompson1894 wrote:I dont know what is under the ply, usually it would be joists from 3x1 (vertical) bolted to the chassis, you could place heavy duty polythene over them, and push 50mm insulation (Kingspan or Poystyrene) in between. Then the ply on top. The polythene would protect the insulation and ply from the wet, and holds the insulation up. Then the ply is screwed at 100mm centres to the joists, and coach bolts to the chassis. As for electrics, the best thing is a trailer board from any car spares place.
Bob Thompson1894 wrote:Richard- a much simpler and cheaper method would be to pick up a cheap caravan, £100-£200 and gut it. You could make the area under the back window into a drop down door and you then have all the room you will ever need. And its legal.
Rob Buckley wrote:Richard, that's just what I meant. As you're fashioning a category O2 trailer from here...
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/277534/guide-to-the-iva-scheme.pdf
...You might have to have an IVA test carried out, unless you've not changed any of the things they inspect (on page 37/38). You kept the lights from the original trailer didn't you??
Rob Buckley wrote:Read the document, IVA now applies to all trailers, no matter what size (unless you declare it agricultural and tow behind a tractor or similar).
Users browsing this forum: No registered users and 37 guests
