- Painted 2.jpg (88.59 KiB) Viewed 17716 times
- Painted 1.jpg (94.32 KiB) Viewed 17716 times
Just a quick update on the progress. The model has now been painted in a satin finish 2 pack acrylic white, by Neil Hyde, thank you Neil. All systems apart from Nav lights are installed and functioning as they should and with batteries the dry weight is 31 kgs. The engine is in and the fuel system plumbed, we had a test run of the engine today in the airframe and on half throttle I struggled to hold it back, so power seems adequate as Rolls Royce say. Mainly a bit of wire tidying to sort out and the Cof G to finalise but as is, its not far off and with the batteries in the correct place no further wieght should be needed. Harolds done a fantastic job framing the cockpit with aluminium which was more than a little tricky given the curves on the cockpit. All in all it should be on the circuit fairly soon. Well done H.
