Postby David Brown » May 17th, 2015, 5:37 pm
Test flew my Jetwelt JP on Friday. All did not go well as I seem to have the c of g too far back making it very sensitive at low speed and I had 5mm of down elevator dialed in after landing or should I say arrival. Knocked out the nose leg & bent a main but no structural damage. I will now recheck my settings when the parts are repaired, it was set at 30% so it should of been OK as my smaller one is set the same and is very stable. When it was flying it handled well and really looked the part in the air and with the 180 it was not short on power, just the low speed was a problem.
- JP 003.JPG (195.75 KiB) Viewed 122728 times
- JP 002.JPG (164.58 KiB) Viewed 122728 times
- JP 004.JPG (178.53 KiB) Viewed 122728 times
