Wendell Hestetler Cessna 152 30%
Re: Wendell Hestetler Cessna 152 30%
Postby Alan Cantwell 1131 » May 4th, 2015, 8:21 pm
Have you vented the carbs Wayne, lead 2 tubes from the front to the carb inlets, brings fresh air to the carbs, plenty of turbelent air at the rear of the cowl, puts the wick out
Wayne Cox
Postby Wayne Cox » May 4th, 2015, 9:03 pm
Hi Alan
Thanks for coming back. At the moment the Cowl is off so I can set up motor.
Sorry to sound thick but are you saying to put tubes from the front and place over the carbs to give fresh air?
Wayne
Postby Alan Cantwell 1131 » May 4th, 2015, 9:15 pm
Yep, the carbs are right at the back, were air batters the firewall, its a popular mod, ive done it, cured an errant running laser 150,, this mod came from niel tidy his self, turned out to be a tidy bit of help, also fit an on board glow, not sure what you would use for a twin,
Wayne Cox
Postby Wayne Cox » May 4th, 2015, 9:21 pm
Yes I can see that as they are not very far from bulk head. You would never have thought.
Is there anywhere I can see the best way to set up or shall I put a photo on here so you can see.
To say the least was scratching my head as I know how good these are
Wayne
Postby Alan Cantwell 1131 » May 4th, 2015, 10:16 pm
Cant find ny pictures on the net, vut it must have been done somewere, ive only done it on singles, the ricket boys use lasers, they might help
Wayne Cox
Postby Wayne Cox » May 10th, 2015, 5:50 pm
So good news started Laser today problem was bottom ends and one of the plugs was failing under load
Planning to test fly next weekend weather permitting
Wayne
Postby Alan Cantwell 1131 » May 10th, 2015, 6:24 pm
Suggest you still do the pipe thing Wayne, its a proven thing,
Wayne Cox
Postby Wayne Cox » May 12th, 2015, 9:39 am
Hi Alan
I have spoken to Laser and he said straight away that it was bottom end and informed me of the settings and after checking img the bad cylinder was way out.
I don't have any photos to go by and the motor is running nice and must say has a lot of power and sounds great
Wayne
Postby Alan Cantwell 1131 » May 12th, 2015, 4:12 pm
Every little helps Wayne, glad its sorted
Wayne Cox
Postby Wayne Cox » May 14th, 2015, 9:20 am
Hi Alan,
It does mate many thanks for your input
Wayne
Wayne Cox
Postby Wayne Cox » May 18th, 2015, 9:20 am
Well test flight completed on Sunday.
Got the Laser 360v singing, my son Sam carried out the test flight she flys great, so smooth in the air very little trim adjustments hands off sticks and she flys straight.
I then took her and did some circuits need to take some expo out on alerons on the landing she came down on rails.
We did a 9 min flight and only used less than half a tank. Now to get decals on and some more flights.
Photos to come and also have video so will post once done
Wayne
Wayne Cox
Postby Wayne Cox » May 18th, 2015, 9:07 pm
Postby Alan Cantwell 1131 » May 29th, 2015, 4:13 pm
Loks a fine flyer Wayne, you must be pleased! Engine sorted now is it?
Wayne Cox
Postby Wayne Cox » May 30th, 2015, 8:16 am
Hi Alan,
Thanks for commenting yes she flys great and the motor is well sorted.
I am installing a Saito FG57 petrol into her this weekend as I decided to stall with petrol as all my other ones are so if you know anyone who may want a Laser 360v I have one for sale.
Hope to see you at shows
Wayne
Wayne Cox
Postby Wayne Cox » June 2nd, 2015, 10:14 am
So new motor installed and very happy all kept inside just need to run her up and fly
Wayne
Wayne Cox
Postby Wayne Cox » June 16th, 2015, 6:14 pm
So we have ran the new motor up and must say she sounds very nice and the power is out of this world.
Test flight tomorrow night.
Nigel Cox
Postby Nigel Cox » June 22nd, 2015, 6:59 pm
Hi Wayne,
Good to see this flying yesterday @ Weston Park :) I'll put some pictures up when I've sorted through them
Wayne Cox
Postby Wayne Cox » June 22nd, 2015, 9:29 pm
Hi Nigel
Many thanks, she flew very nice am very pleased with the motor going to do some tests on some props.
I put her on the BelAir stand afterwards and she got a lot of interest.
She is hopefully at Cosford and Much Marcle.
Look forward to seeing photos.
Kind Regards
Wayne
PS now talking about the Bananza 36 at 108" 27% to build
Nigel Cox
Postby Nigel Cox » June 22nd, 2015, 10:04 pm
Here's three to start with.
What happened to the 172/182 in your second slot, that did an inverted pass then all I heard was a sickening Thud !!
Wayne Cox
Postby Wayne Cox » June 23rd, 2015, 11:02 am
We'll both of us were trying to fly as a pare then Clous split off I was watching the inverted and next thing is we are being asked to land to be honest not sure after that.
Great looking photos can't wait to see others
Wayne
Users browsing this forum: No registered users and 33 guests
