With the (slightly!) warmer weather we've been having recently I decided to get the moulds laid up for the wheel spats, tail cone and nose cone.
The plugs have been finished a few months now to give them time to properly harden. I'm not sure what I did wrong last time I made moulds but they stuck like glue!!!
I gave the plugs 5 coats of Mirror Glaze wax before I made some parting boards from conti-board, not sure if this is a universal name but it's basically chip board with a plastic surface each side....for making cheap shelves and stuff. I bonded this to the plug with some hot glue which did a good job.
The gap between the parting board was simply filled with some plasticine to get a perfect fit before I have the whole lot another 2 coats of wax.
- image.jpg (67.7 KiB) Viewed 65859 times
You're probably wondering why I made the tail cone integral with the wheel spats! Basically, I didn't have enough conti-board and being the cheap skate that I am I made do!!
An area I had never had much luck with was PVA release agent! Usually it just beads up and looks awful....I had tried wiping it on with a cloth, better but you could still see the wipe marks in the finished moulding. I have it a lot of research and bought some fresh PVA release agent and tried again. Using an iwata airbrush turned upto 80psi, thinned PVA with 30% water and spraying ever so lightly I hit the eureka moment! Too little spray and the PVA simply dusted onto the surface and left a mottled effect, too much and it beaded up again, but at a fraction more than a light dusting it settled down a treat and left no discernible layer!
The gel coat was mixed up using West Systems Epoxy, 10% colloidal Silica to thicken it and also 10% graphite powder to provide the dark colour and also provide a low stick surface for the final mouldings.
This was left to go 'green' a state where the epoxy has lost its tackiness but you could still indent it with your thumbnail. I mixed up some West epoxy and milled fibers to a thick paste and went around the sharp concave corners that you know glass cloth won't conform to!
- image.jpg (97.96 KiB) Viewed 65859 times
Then 6 layers of 165 gram cloth was laid up with west epoxy and left to harden over night. I tried using a powder bound chopped strand Matt for building up some thickness to the moulds but it needed a huge amount of working to get the resin soaked in.....not to mention a huge amount of resin. I gave up a just used the cloth I had to hand!
After removing the parting board and laying up the second half.....the moment of truth arrived. Will I get this great mass of epoxy apart?
- image.jpg (98.23 KiB) Viewed 65859 times
I'm not sure what did the trick, leaving the plug to properly harden, the PVA or the graphite in the gel coat, maybe a combination of them all, but the two halves released easier than I have ever known moulds release!!! I don't know what I did, but something went right!
- image.jpg (71.19 KiB) Viewed 65859 times
