Barrie King wrote:Hi Richard, a 38cc NGH Fourstroke petrol would suit.
Barrie
Alan Cantwell 1131 wrote:Set it up with the the down going aileron moving half as much as the upgoing, this basically stops the wing getting into a stall situation, and getting aileron reversal, ie, the downgoing ailwron creates drag, rather than lifting the wing, it stalls it, and the wing drops, quite common on things like moths, cubs etc, I once asked a friend if he was ok for the testflight of his plan built 1/4 moth, he said he had to do it sometime! He had got the differential the wrong way round, one tranny thrust into my hands later, and flying behind the pits, i got it down, only to get a bollocking for flying behind the pits, i erm, put them right lol!
Tony Collins 1073 wrote:Richard, Aileron differental means that the down going aileron is set with much less movement than the up going one.
The reason this is necessary more so on some models than others is that the down going aileron creates more drag
than the up going one and will pull the aircraft toward the side of the down going aileron. This can be held with rudder
but if you have the correct aileron differential no correction is necessary.
Anything to make our life easier eh. Good luck with the model and never take anything for granted.
Tony.
Users browsing this forum: No registered users and 70 guests
