Since 1994,my 1/7th scale Vulcan has been flying around the uk shows--starting life with Super tiger 45cc engines---then soon replaced with 2-Zenoah 62cc,then a few years back,converted to twin turbines.I intend retiring this model at the end of the 2010 season,so earlier this year decided to look at building a replacement.After much discussion with members ,i decided at the 1/5 th scale size,which brings it out at 20ft wingspan.The main reason for this ,was the 10ft Vulcan i have been displaying for new member Rob Greenwood--this model was built by Alan Walker from the Hucknall club,and is super scale---so i talked Alan into letting me borrow the plans,and had them doubled in size---and the outcome is the basic structure to be seen at last months Gaydon show,kindly cut by Richard at Falcon Aviation.Since Gaydon,i have been slowly working on the main fuselage structure,glueing and jigging all the formers.Also the tail cone has been built and stringered,ready for covering with Balsa.The tailcone and Fin fixings have been designed and fitted---a couple of piccies of the build so far are attached.The main structure will be covered in epoxy sheeting,and nose/tail will be balsa covered.I intend fitting 5 seperate 2.4 radio systems,situated in wings and fuselage ---the scale undercarriage,with 24" long legs ,is being constructed by an LMA member locally.The final weight i am hoping to be not much more than my 1/7 th at 150lbs,and the power will be 4 .160 turbines,instead of the 2 in the existing model.I am hoping to get the two main wing panels built and ready for stringers this week,will post some piccies when these are done---[attach
- Vulcan build pic 2.jpg (45.72 KiB) Viewed 69659 times
ment=1]Vulcan build pic 1.jpg[/attachment]
