Hi all, now you might be thinking what’s the point of this thread it is only a trainer? Pretty straight forward I would of thought,’ well you might be right’ but this will be a challenge for me because I have never build anything before so I hope you will indulge me.
After opening the packing from slec which I have to say was pack very well, I dug out the plans, oh boy where do I start? Well thankfully the plans are not as daunting as they first look so after having several cup of tea and pondering over the plans I cleared the work table and started to identify the parts and numbering them.
The attachment numbering 1.jpg is no longer available
Once all the parts was numbered I then sat and had several more cups of tea, I think I was just putting it off wasn’t I,
I mean how hard it can be!! ‘I’m sure I heard some say that before’ right time to get the Stanley knife out and with that I started to cut out the wing rib and all that stuff.
- cutting out 1.jpg (34.63 KiB) Viewed 80361 times
Okay the next stage, arr you though I was going to say after several more cups of tea didn’t you well you would have been right only her indoors polity told me to ‘go away in short jerky movements
‘I have no idea what that means ‘I’ll never understand them’
so with losing access to my tea supply I had no option but to carry on, so with sandpaper in one hand and parts in the other I proceeded to sand all the rough edges down.
- sanding 1.jpg (23.44 KiB) Viewed 80358 times
Next I assembled all the parts and got ready to do battle, I decided to do the wing first.
- wing parts.jpg (23.06 KiB) Viewed 80359 times
Following the plan I found it easy to slot all the parts in place thank god I took the time to number them all I would have been lost if I hadn’t , I decided to dry fit all the parts first just in case I make a mistake.
- assembley 1.jpg (22.51 KiB) Viewed 80357 times
- assembley 2.jpg (26.57 KiB) Viewed 80358 times
- assembley 3.jpg (23.2 KiB) Viewed 80356 times
Okay that's it for now.
