Sky 120 LMA Trainer
Geoff McVey
Re: Sky 120 LMA Trainer
Postby Geoff McVey » July 17th, 2018, 2:50 pm
Fuselage Step 11
T nuts ready to be epoxy to part F20 to secure the wing.
T nuts epoxy to F20 and cleaned up a little
Side view of part F20.
Geoff McVey
Postby Geoff McVey » July 17th, 2018, 2:54 pm
Fuselage Step 11
T nuts ready for epoxy to part F13 engine firewall.
Rear view of F13 engine firewall, T nuts epoxy and cleaned.
Front view of F13 engine firewall T nuts epoxy and cleaned.
Geoff McVey
Postby Geoff McVey » July 21st, 2018, 6:00 pm
Fuselage Step 2
Part F3 glued in place to F1, and set at 90 degree angle.
Geoff McVey
Postby Geoff McVey » July 21st, 2018, 6:02 pm
Fuselage Step 3
Part F4 glued in place to F1, and set at 90 degree angle.
Geoff McVey
Postby Geoff McVey » July 21st, 2018, 6:05 pm
Fuselage Step 7
Part F6 glued in place to F1, and set at 90 degree angle.
Geoff McVey
Postby Geoff McVey » July 21st, 2018, 6:12 pm
Fuselage Step 12
Fuselage side parts F7, F8, dry test fit and fit well together to parts F3, F4, F5, F6.
Geoff McVey
Postby Geoff McVey » July 21st, 2018, 6:14 pm
Fuselage Step 15
Parts F9, F10, dry test fitted then glued in place.
Dave Parry
Site Admin
Postby Dave Parry » July 23rd, 2018, 6:53 am
Looking good Geoff, keep up the good work.
Geoff McVey
Postby Geoff McVey » July 24th, 2018, 6:33 pm
Dave Parry wrote:Looking good Geoff, keep up the good work.
Hi Dave,
Many thanks.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:33 am
Fuselage Step 13
Part F20 glued in place, then parts F21 glued to lock F20, T nuts already epoxy before fitting part F20.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:38 am
Fuselage Step 14
Firewall F13 glued in place, then parts MF1 glued to support F13 firewall.
Parts MF1 trimmed.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:40 am
Fuselage Step 17
Parts F25 glued in place to support U/C.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:45 am
U/C Part 1
Bolts, T nuts test fitted in place, bottom view.
Bolts, T nuts test fitted in place, top view.
Bolts, T nuts test fitted in place, side view.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:49 am
U/C Part 2
Holes drilled on part F26 fuselage bottom skin.
Holes drilled on parts F25.
Dry test fit of U/C with holes drilled, all lined up correctly, no issues.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:54 am
Fuselage Step 18
Part F26 glued in place.
Once glued U/C bolts added to help keep down and no movement.
Masking tape added to keep the rest of part F26 from moving.
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 9:56 am
View from inside the fuselage, some light sanding needed.
Postby Bob Thompson1894 » July 26th, 2018, 10:00 am
nice neat work. Carry on.....
Geoff McVey
Postby Geoff McVey » July 26th, 2018, 10:01 am
Bob Thompson1894 wrote:nice neat work. Carry on.....
Hi Bob,
Many thanks.
stuart knowles 1611
Postby stuart knowles 1611 » July 26th, 2018, 12:58 pm
It all looks a bit 'Brick Outhouse' but having seen them fly, it must be fine.
Neat building, keep posting
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:15 pm
stuart knowles 1611 wrote:It all looks a bit 'Brick Outhouse' but having seen them fly, it must be fine.
Hi Stuart,
Thank you, will keep posting.
Users browsing this forum: No registered users and 30 guests
