Wellington build and re-build
Steve Vodrey
Re: Wellington build thread
Postby Steve Vodrey » November 14th, 2023, 9:15 am
Trusty sliding battery tray back in position
Downsized tray.jpeg (298.89 KiB) Viewed 64484 times
Cockpit glass in position ready for planking
Cockpit downsized.jpeg (294.57 KiB) Viewed 64484 times
Robin Senn
Re: Wellington build and re-build
Postby Robin Senn » November 15th, 2023, 4:36 pm
Hello Steve
Now thats a pitty to hear about the crash of your Wellington. In the first pictures that looked like a case for the bonfire and not for the building table. I really admire that you are rebuilding the plane, thats something I wouldnt have the stomach to do. So cudos to your will and apparent progress. I will be following for sure.
What kind of engine trouble did you have with the plane before the crash?
Best regards
Robin
Steve Vodrey
Postby Steve Vodrey » November 17th, 2023, 5:13 pm
Hi Robin. It's coming along. Always quicker than building a new one.
This is todays progress.
reduced planking.jpeg (254.14 KiB) Viewed 64393 times
As for the engines, well the 26 Zenoah can be troublesome but after carb bits etc I had them sorted than had a signal loss which was terminal. Different RX in the re-build when it's done.
Robin Senn
Postby Robin Senn » November 20th, 2023, 6:50 am
Hello Steve
Wow, quite some progress! You are really pouring it on. And yeah, I also a have a special drawer for those "no longer to be trusted" RXs. Will you be staying with the Zenoahs, or are you thinking to change them too?
Best regards
Robin
Peter Siggins
Postby Peter Siggins » November 20th, 2023, 3:04 pm
Hi Steve as you know I’m a convinced Zenoah person .Very unfortunate to have crashed your Wellington,but the repairs look like going well.
Reason for post is something that has occurred twice in my last visits to our field,both times on different 26 Zenoahs ,of which ihave six in different models. The metering needle has stuck ,so the engine won’t start,a quick removal of the metering cover and blowing some pressure to the fuel system while pressing the sprung needle till fuel runs through - problem solved and engine totally reliable. I’m putting this down to the additives used in modern petrol even though I using the 5% super unleaded.
Just thought you may have the same trouble at sometime - all the best with the rebuild.
Steve Vodrey
Postby Steve Vodrey » November 20th, 2023, 8:20 pm
Sticking with the Zenoah 26 pair as I will give them a good thrash around one at a time in a smaller model. They do fit well in the cowl and power output is ideal.
This was the cause of my engine problems this year.
reduced bung.jpeg (132.32 KiB) Viewed 64317 times
This got to the filter in the carb
reduced green snot .jpeg (366.18 KiB) Viewed 64317 times
Thanks Pete for the engine tips. I believe the ethanol in petrol is responsible for a lot of our problems.
Robin Senn
Postby Robin Senn » November 21st, 2023, 10:40 am
Hello Steve
Yup, thats some serious gunk in the filter. No wonder the Zenoahs acted up. I switched to synthetic fuel about 12 years ago and never looked back since then. Less smelly, and no issues with the ethanol. It is costlier but as I use exclusively 4 Stroke engines fuel consumption and cost are much less an issue than with two strokes.
Best regards
Robin
Steve Vodrey
Postby Steve Vodrey » December 4th, 2023, 11:14 am
Well its time to get on the wings which are also a bit of a mess...
Reduced wings.jpeg (328.27 KiB) Viewed 64148 times
slow progress. Bit of a jigsaw really.
Reduced ribs.jpeg (282.39 KiB) Viewed 64148 times
CNC cut parts are a must to save time. Big thank you to SLEC.
Steve Vodrey
Postby Steve Vodrey » December 31st, 2023, 5:21 pm
Annoyingly one of the wing tips was damaged more than I realised.
damaged tip.jpeg (284.34 KiB) Viewed 63854 times
Underside soon repaired and tip replaced.
repaired tip.jpeg (254.92 KiB) Viewed 63854 times
Robin Senn
Postby Robin Senn » January 1st, 2024, 10:43 am
Hello Steve
First a happy new year to you. I am still in awe about your progress (and perseverance) in the face of such damage. Those wings would admittedly have been a lost cause for me...
One question: how do you check the "surviving" parts for hidden damage?
Looking forward to see more of this ressurection... :D
Best regards
Robin
Steve Vodrey
Postby Steve Vodrey » January 10th, 2024, 6:48 pm
Hi Robin.
Happy new year to you too. Most of the damage is of course visible. The fuselage is easy to check as for the wings it's a case of removing some of the covering and open up where needed such as the wing tip. Stress tests can be applied also to reveal weaknesses.
Steve Vodrey
Postby Steve Vodrey » February 11th, 2024, 7:41 pm
Work continues mostly on the wings. They are nearly ready for covering now and all lined up. At last the model is taking shape.
Rear view.jpeg (296.38 KiB) Viewed 63234 times
front view.jpeg (254.41 KiB) Viewed 63234 times
Many thanks to Paul from Kingfisher for making the cowls which has saved me lots of extra work.
Robin Senn
Postby Robin Senn » February 14th, 2024, 6:35 pm
Hello Steve
Great progress there Steve.The repairs are coming together niecely as it seems. And nice cowls. Looking better (and definiterly sturdier) than the vac formed ones i use.
BTW, I see that you have also installed flaps on your Wellington. How is your experience with them, and what settings are you using? I am still experimenting with mine and havent found the ideal setting yet.
Best regards
Robin
Steve Vodrey
Postby Steve Vodrey » February 19th, 2024, 7:49 pm
Hi Sean.
Thanks for your comments. I'm busy gluing strips of balsa on the outside of the fuselage at the moment
The flaps are very effective at full deployment which is about 60 degrees.
There is no need for any elevator mix as the pitch remains fairly constant. It will drop in from height quite steeply but still flare out. I did exactly that at Cosford one year and heard a gasp behind me to see that it was Tony Nijhuis. :D
Steve Vodrey
Postby Steve Vodrey » February 23rd, 2024, 7:34 pm
Well after many more hours its ready for covering.
reduced longerons.jpeg (276.5 KiB) Viewed 63026 times
Peter Siggins
Postby Peter Siggins » February 24th, 2024, 10:38 am
Crikey Steve you’ve got some patience - great rebuild job.I think if it had been me I’d have scrapped it!
Cheers Pete
Steve Vodrey
Postby Steve Vodrey » February 26th, 2024, 7:30 pm
Thanks Pete. Will be done before too long.
Robin Senn
Postby Robin Senn » March 5th, 2024, 12:15 pm
Hello Steve
Thats looking fantastic....and as good as new..or even better..;-) I have to agree with Pete, I wouldnt have had the will for such a rebuild. Great job.
And thanks for the information about the flaps. I am using a bit more flaps at the moment, around 75 degrees. Maybe that the reason why I need a bit of elevator down trim when the flaps are deployed.
And it must have been a great moment having Tony admiring you landing..... ;-)
Looking forward to you finishing the rebuild.
Best regards
Robin
Steve Vodrey
Postby Steve Vodrey » March 31st, 2024, 1:45 pm
Not sure Tony was admiring my landing or watching in horror!
Anyway. Got some paint on it now.
Paint your welly.jpeg (244.23 KiB) Viewed 62705 times
Steve Vodrey
Postby Steve Vodrey » June 2nd, 2024, 3:51 pm
Well after many more hours of re-installing engines, tanks and radio I got to test flight time yesterday.
Not the best of days for a test flight but the wind was down the strip and we got the engines running well.
All was fine with the usual landing at tip toe speed thanks to the flaps, and the wind.
Now to get it properly finished.
reduced Cowls.jpeg (244.42 KiB) Viewed 62116 times
Reduced front Turret and canopy.jpeg (240.23 KiB) Viewed 62116 times
Sorry but no video of the flight this time probably owing to people keeping out of the way :D
Users browsing this forum: No registered users and 99 guests
