I had the opportunity a few months ago to acquire from David Pearson his 1/4 scale Sea Fury which had been superbly built by Tim Simmonds from the Jerry Bates plan,although the model had been statically shown at several Cosford's and Duxford static displays and earlier this year had been final inspected and a permission to test fly obtained,it had not been flown.
The necessary procedures were followed to register the change of ownership,obtain a new certificate of construction etc through the over 20 kg scheme and subsequently a new permission to test fly from the CAA has been received,unfortunately the weather and my own business committments have prevented anything happening in this regard.
The model did sport something of a 'showroom' finish which I have dulled down with Scotchbrite pads, fine wire wool and the whole airframe has been dirtied up somewhat with graphite powder,washes and the like,I have added detailing to the exhaust and emergency canopy release areas along with exhaust,oil and cannon gas staining,additionally maintenance,warning,squadron and mission markings have been sprayed on using stensils and masks from Nigel Wagstaff of Flightline Graphics - I cannot give but the highest recommendation for Nigel's product and the service he provides which is truly first class.
Power is from the obligatory Moki 250cc radial,so this along with the one in my Corsair means I have the perfect power plants for a future decent sized Beaufighter or Tigercat - roll on retirement and extended building opportunities - the radio link is via twin Futaba 6014 receivers through a Powerbox RRS and backer set-up,servos are predominantly JR8911 and 8711 items.
Attached are a few pictures and items I have been making for the cockpit,the armour plate headrest is from balsa with the leather covered headrest from epoxy coated blue foam,the 4 main instrument blank panels are from balsa covered in 0.006 inch ali suitably edge folded,instruments,switches etc will be added when the festive spirit runs dry in a day or two,will post a few pictures of the assembled model when the weather improves,can't wait to fly the thing and when appropriate may be get together with the other 2 or even 3 other quarter scale Sea Fury's sometime next year.
Regards Trevor Wood LMA 687
- Sea Fury 2010 011comp jpg.jpg (14.5 KiB) Viewed 20952 times
