Rob Buckley wrote:Andy,
As your calcs give a max stress in the spar of 77.9MPa, this looks to be smack in the range of the bending strength of the Cyparis. Wouldn't the simplified spar fail at this load, most likely in buckling of the top element at the fuselage joint?
I'm assuming the spar is basically modeled as a rigidly supported beam at the fuselage edge, with the load uniformly distributed?
The strength you quote of 6500 - 12100MPa seems very high. 300M extra high strength steel that we make the Airbus landing gears out of has a UTS of 1970MPa & a 0.2% yield of 1655MPa. Good though Cyparis is, I'm pretty sure 300M is stronger!
http://www.thewoodexplorer.com gives the properties of cyparis as 82MPa bending strength and 40.6MPa compressive strength, which would seem to match real world wood spar performance.
Happy new year!
Rob
Then he has learned a valuable lesson! When training, always have the throttle at high idle, and keep hands off the controls apart from the trainer switch...... This is one of the reasons why 40 powered trainers are better than the Greenly type for raw beginners, the stresses involved in training are just too much for wild manoeuvres!Andy Boylett wrote:Hi Nick,![]()
I did the sums on 5g but showed examples of how it could easily handle higher loads. I have seen deisgns for the extreme aerobatics planes at 10g. From what I have read the highest wing loads for us could rather perversly be not due to flying but due to landing. It is very easy when landing to bump the floor a little and cause an impact loading which resuts in very high g flex of the wings downwards.....obviously impossible to calc as it all depends on the flexibility of the UC and fus.
The highest g turn I have seen pulled in flight was by one of our club instructors who was training a young lad (with my trainer plane). The trainee dived for the ground at very high speed and so the instructor decided to take back control of the plane. However, before releasing the trainer switch he had already applied full throttle and full up elevator. The result was a completely snapped wing!
Users browsing this forum: No registered users and 13 guests
