The pushrods and ignition cables need adding to the dummy radials....
- image15.jpeg (138.96 KiB) Viewed 15219 times
- image7.jpeg (171.56 KiB) Viewed 15219 times
- image11.jpeg (84.1 KiB) Viewed 15219 times
Oh...and the nosewheel seems to have very limited steering so this needs some attention before flying....other than that I need to run the engines and make sure the settings are still good and then charge her up and go flying!
The final all-up-weight came out at 31.3kgs or nearly 69lbs. I'm pretty happy with that as I guessed the final weight to be 70lbs at the start of the build...do I get a prize?
She still feels very heavy to pick-up though and that sharp stall she had when weighing about 5lbs lighter is giving me nightmares! I think I might keep a bit of safety speed for the first few landings...if not all landings!
The weather is pretty bad at the moment but hopefully things will pick up early next week so I can get this Over 20kg testing finished off and then gain the final paperwork so I can take her to some events.
I'll keep you posted........
