Craig Green
Postby Craig Green » April 3rd, 2016, 1:30 am
Thanks Dave, it is a work in progress, still so much to do, but bit by bit I will get there.
Craig Green
Postby Craig Green » April 3rd, 2016, 9:28 pm
Cut out the hatch area over the main spar mount.
Using my Zona saw and a razor blade, I removed the piece.
I will be using two screws to hold it into location. Have added support rails, it is a nice tight fit.
I will have lots of room inside to mount the wings and do the electronics.
Craig
Craig Green
Postby Craig Green » April 11th, 2016, 3:37 am
Finished up the access hatch, nice fit.
Have also been sanding and filling the inboard wings, have applied some primer on the top surface which will be Sanded down to smooth out any issues.
Craig
Craig Green
Postby Craig Green » April 12th, 2016, 4:13 am
Sanded down the primer with 320 wet paper. I prefer wet sanding, paper last longer, and you can clean as you go.
Engine nacelles still need to be constructed, but I like the look of the wings with some paint, starting to look like something.
Craig
Before sanding
After sanding
Postby stuart knowles 1611 » April 12th, 2016, 8:05 am
Looking good, very good!
stu k
Craig Green
Postby Craig Green » April 13th, 2016, 12:48 pm
Thanks Stu, always something to do.
Began work on some fuselage Windows. Layed up some glass, cut it to size and removed the window pane portion.
Marked and cut out the frame on the fuselage. Sanded down a recess for the glass piece then glued it into location.
The plastic window will be installed after painting. Happy with the results so far.
Craig
Craig Green
Postby Craig Green » April 15th, 2016, 4:43 am
Did some filling and sanding, added some primer, it turned out pretty good.
Will sand it back later before doing panel lines.
Craig
Craig Green
Postby Craig Green » April 16th, 2016, 9:16 pm
Gorgeous day today, so I decided to set up the Lanc for the first time.
The shade of the trees offers a bit of camouflage.
Craig
Postby stuart knowles 1611 » April 16th, 2016, 10:37 pm
Looks good to me
Postby Dave Parry » April 17th, 2016, 6:37 am
Now that's looks the part Craig, it is going to be a stunner when it is finished.
Craig Green
Postby Craig Green » April 29th, 2016, 3:42 am
Thanks Dave.
Did some work on the front turret top cover.
Made of balsa, shaped and glassed. Attached it to the top of the fuse.
Made a fillet of epoxy, filled with spot putty, and a coat of primer.
It still neds some more sanding and filling, but happy with the look.
Jason Griffiths
Postby Jason Griffiths » April 29th, 2016, 7:36 am
WOW she is lovely well done Craig i bet your over the moon with how it looking and coming on .
Thanks 8-)
Arthur Fielding
Postby Arthur Fielding » October 4th, 2016, 10:45 pm
Could you tell me the length and wall thickness of the tube you used to support the two half's of the lanc fus .
Thank you
Arthur.
Craig Green
Postby Craig Green » October 5th, 2016, 1:55 am
Hello Arthur.
I made my own tubes out of glass cloth and resin.
I do believe they are about 1/16 on an inch, or 2 mm.
They are pretty strong, and secured to the 1/8 ply fuse formers.
Craig Green
Postby Craig Green » October 5th, 2016, 1:58 am
Almost time to get back into the shop. Summer is closing fast here, so I hope to start plugging away on the Lanc, so much more to do, but more fun to come.
Craig
Arthur Fielding
Postby Arthur Fielding » October 5th, 2016, 9:05 am
Thanks for the quick reply ,but you did not mention the length of the tube. I am looking at building the slec wellington but will have trouble transporting the finished model .I have had good advice against building a three piece wing, but having seen your Lanc build ,a two piece fus would solve some of my problems. I fully appreciate that at the end of the day its all down to me, but all advice is appreciated, and it looks to me that you know what you are doing.
Thanks again
Arthur
Robert_Greenwood
Postby Robert_Greenwood » October 31st, 2016, 7:54 pm
Hello Craig,
As much as people think i'm a gonner, i am still around. Very busy with my new GF and child. :)
Your thread is giving me a building bug, i vowed never to build again...
With regards to the vertical fins, i went over the top with everything i added wooden dowels and two bolts. I had seen a tail fin come off a Lancaster at a show once.
I bought the cowls from Falcon Aviation, also the spinners and wheels from him too.
Now for the tail wheel, i had a disaster with the tail wheel on mine. On a test day before she had ever even flown i took her to my local flying field. Powered her up to do a taxi test, off she went...then suddenly the tail wheel bent over and BANG-CRASH!! I immediately closed the throttle but she kept on going right into another members brand new model ... to make matters worst in my panic i hit the retract switch (thinking it was engine kill) so yes you guess it she didn't just eat the other model she sat on it too haha
I laugh now but at the time i was gutted! :) :) so a strong tail wheel is needed if you ask me.
Keep up with the good work.
Kind regards
rob
Nick Reeves 3055
Postby Nick Reeves 3055 » November 2nd, 2016, 8:08 pm
have you still got your lanc robert?
Robert_Greenwood
Postby Robert_Greenwood » November 3rd, 2016, 2:02 pm
Sadly not Nick it was sold to a guy in Greece one of my many mistakes in life, but i feel there maybe Lancaster Mk2.
After seeing Craig build his i can see so many areas where i could of done it better, the Lancaster was my first ever build. Before that it was a tutor 40.
Craig Green
Postby Craig Green » November 4th, 2016, 1:54 am
That's quite a big job after a tutor 40. Just goes to show that you can do anything if you put your mind to it.
Arthur, sorry for not responding fully to your earlier question, the fuselage tube is 54 inches long. I wanted to ensure that it is attached well to the formers. As well I went as far to the rea, so that the entire structure also will support the tail wheel, which has yet to be thought of.
Have been working on mounting of the fuel tanks, there is plenty of room to place them as close to the main spar as possible.
More to follow as I progress.
Craig
