Chris Lane wrote:http://www.modelfixings.co.uk have them.
Chris,
thanks for that, great shop.
Andy
Andy Boylett wrote:Hi Mark,
can you please help me calculate the loads that would be invloved and explain why a circlip would not suffice?
Mark Partington 2989 wrote:Andy,
... I've had a thought about where circlips would be used, and concluded they are only used to stop things like bearings sliding out of position, holding shafts in place or as a secondary retainer for other fasteners.
Mark
You're not listening to what I said.
The reason for redundancy on the fasteners is nothing to do with engineering design, but simply because without it the connection is not considered safe.
Ref you point about full size 'horns- for manual control they vary in 'length' between 25% and 50% of the distance from hinge to trailing edge at MAC, (rudder horns tend to be shorter than elevator as the pilots legs are more powerful than his arms), so not what you refer to as a 'short control throw', in fact probably longer than a lot of models. Even fully powered controls use a 'horn' as long as possible- e.g. surface length approx 40cm, 'horn' length 9cm (that's on a mach 2 fighter btw) or surface length approx 200 cm, 'horn' length of 35-40cm (500+ ton airliner), check out the elevator horn on a Spit or Hurri.
back later with more.....
Mark
Phil Clark wrote:Aileron hinges..............
1) How are the bolts accessed?
2) I assume the st/st tubes are bonded into hadwood blocks?
2) What provision has been made inside the wing to prevent the thin edge of the st/st tube cutting into the underside of the bolt head?
Phil Clark wrote:1) Sorry Andy, I may not be a trained engineer, but I am FULLY aware of the differences between a 'C' clip and a Circlip
2) I obviously have hands like shovels as I find small CIRCLIPS very delicate & easily damaged
To answer your question regarding circlips showing signs of wear....yes I have. A slightly different application I agree, but on some retract spool valves I use, they use 2 circlips to retain the spool in the valve and act as end stops. Some cheap valves have used C clips, better quality ones circlips. I have had one instance where one of the better quality valves 'started' to fail (I spotted it before it became a problem) because the shallow grove the circlip was seated in started to show signs of wear around it's edge and the circlip had started to jump out of the groove. The circlip was obviously a hard spring steel of some sort, the spool of the valve was softer aluminium. The valve had not been tinkered with; the wear was due to vibration and general wear & tear. A retract valve is a relatively non critical piece of kit....we can cope if our wheels don't go up, or won't come down.........in your application??????
I see you are now fitting a split pin in addition to the Circlip......this is perfectly acceptable as this will serve 2 functions in helpingIt to prevent the circlip coming off if it does becomes loose, and preventing the clevis shaft falling out in the event of a circlip failure.
Andy Boylett wrote:Phil,
I have seen those on retract spools as well (just sold a set of new ones, Dave now has them!). The valve puts its load 'full on' and 'full off' on the clip you talk about. It is also a considerably high load to be putting on a small circlip - we all know just how much force is needed on the end of the shaft, sometimes they are difficult to move . Not surprising it can wear then. The clevis pin application I am talking about is 90 degress different in that it does not take the load and has no inherent loading on it at all.
Andy Boylett wrote:I was not proposing a split pin in addition to a circlip, instead of.
My other idea was to drill/tap the end of the pin and fit a 2mm bolt in it (threadlocaked of course).
Andy Boylett wrote:You also looked at and approved the Protech fittings in November (for me to use as hinges on the rudder and elevator). I showed you one made up. There are lots of photos near the start of this thread (a little way down page 1 there are photos). This is why I ordered 100 circlips.
