The Forsythe saga (sorry, I meant clevis)
Here is a picture from an engineering catalogue showing the standard endings for 3mm to 20mm rod ends for pnuematics fittings (high impact velocity and vibration). I think this shows quite nicely the options available. A bolt would not normally be used (unless you can get straight shank) because the thread quickly flattens and then becomes loose.
- R3406-aluminium-clevises.jpg (23.05 KiB) Viewed 14395 times
The circlips I ordered to replace the spring clips on my Protech Clevises arrived and myself and Phil tried them on the clevis pins..
- IMG_2796.JPG (28.43 KiB) Viewed 14395 times
- IMG_2798.JPG (29.55 KiB) Viewed 14395 times
The photos show the spring slips supplied with the fittings alongside a circlip I ordered.
They are not bad, but they are also not briliant as the circlip is .35mm thick and the spring clip is 0.58mm thick. Since the groove in the clevis matches the spring clip it leaves the circlip a little loose from side to side. Also, I could only fit the circlip with the use of a magnifying glass as it was too small for me to handle....when fitting an external circlip it must only be opened up just enough to clear the shaft it is going on to - If it is opened more it will be permanently deformed adn then be loose. This could not be done well out on an airfield. Conclusion, use the circlips on the elevator and rudder hinges (that will likely never be removed) but not on the aileron control link.
So, I started searching for some of the retention clip type pins (top left in the top photo) and while doing this I came across the specification for the 3mm fittings. Is anyone aware that the load rating for many of the 3mm clevises and threaded rod we use is 15kg?.....yes, just 15kg.
Also while seaching I found that the big rc suppliers (extreme size planes etc) all supply their fitting in m3 or m4 depening on size of plane. Now this is quite interesting because it ties in with me finding the spec for 3mm fittings is a little borderline and i should be using m4.
Now the next finding. If I go to m4 fittings we are now in the size range of all the standard engineering component manufacturers who usually supply from m4 upwards (m3 is obviously mostly just made specially for RC). Check these out for example, just £1.43 for an m4 fitting...
http://www.ondrives.com/bearings-clevis-components-m4-m16.htmlNice fittings.
Also, m4 ss threaded bar is stiff enough to use (for short push rods) without having to encase if carbon tube.
