The peoples projects
Re: The peoples projects
Postby Phil Clark » September 25th, 2013, 8:06 pm
All done on the Corsair & delivered to the customer yesterday.........next in line are the 1/5.5 Do335 & the fuselage/cowling plugs for a 1/3.4 FW 190D.
Aaron norman
Postby Aaron norman » October 24th, 2013, 8:00 pm
Managed to get a few hours on the la7 today only a few more things to do and the finaly some paint
rob ellis
Postby rob ellis » October 25th, 2013, 3:55 pm
Nice,,,,,,,arron,,,,, very nice,.,.,.,.if you was flying a 109 the last thing you'd want on your tail was one of these,,,,,,,
chris willis
Postby chris willis » October 25th, 2013, 5:53 pm
Stunning Aaron, look forward to seeing it done :)
Aaron norman
Postby Aaron norman » October 25th, 2013, 8:36 pm
Cheers gents .yes rob you really wouldn't want one of them on you 6 try to pop you out of the sky . This has been a really weird project for me, as the la7 was one of my least favourite planes but the more I got into it the more I began to like the lines of the aircraft .and now love it I hope I'm doing the right move with engine choice moving from a zenoha gt80 to the dle111 for a bit mor omph .
rob ellis
Postby rob ellis » October 25th, 2013, 11:18 pm
Ive gone the oppisite way,,, in my meister p47 ive gone from a dle112 to a zdz80,,, I couldnt stand to plugs & caps poking out the sides,,, although I guess it could of been mounted 12o clock 6o clock,,,,,, anyway what scheme is the lavochkin going,,,,, id personally like a yak 9,,,,,
frank fearn
Postby frank fearn » November 18th, 2013, 8:46 pm
A little more progress on the Tiffie...tail-wheel in and functional, cowl mounted to suit Quadra, canopy capers again, primed and panel lined...waiting on the mains to get the wing to same state...
rob ellis
Postby rob ellis » November 18th, 2013, 9:43 pm
Looking good frank,,,,, that pilot is going to take some beating,,,,, can I ask what he is,,,,
frank fearn
Postby frank fearn » November 18th, 2013, 10:30 pm
Postby stewart clifford » November 19th, 2013, 7:29 pm
That pilots the business, Tiffie looks very good too.
frank fearn
Postby frank fearn » November 19th, 2013, 9:23 pm
Shame most of him will be hidden away.
Frank
Postby sean smith » November 29th, 2013, 9:19 pm
Tail section of the Mosquito now done (apart from covering the rudder). Rudder and elevator controls fit under the tailcone, next job is to move onto skinning the tops of the wings ready for the models next inspection.
laurent beldame
Postby laurent beldame » December 17th, 2013, 1:55 pm
Good afternoon Sean
As I visit time to time the forum to watch the mosquito building progress, I ve noticed that you are looking for cowls..
I ve ordered 2 cowls to Richard which has been used for 3 blades props . As the trial tests on the first flight proved that the 3 blades were quite disappointing I ve switched to 2 blade props..(and kept the 3 blades + cowl for static purposes).Facing to this situation Richard was unfortunately not in a position to supply new ones so I ve made a mould to make my owns ones in carbon fiber based on Richard's part.They works very well. If you are interested I can supply you one 1 piece which can be used as a perfect master for your own mould (easy to do). However, regarding the metallic back part you ll have to find somebody to make them : in this respect I can give you as well the proper dimensions...
My return of experience of mossie construction showed me that it is everything but "a long quiet way" compared to a single engine fighter and give some lessons of humility. Do to its size and weight I had to find my own way out of the modeller's business..to gain "technical independance" and easy spare parts access when things goes wrong .
Bon courage and best regards
L
Postby sean smith » December 17th, 2013, 3:50 pm
Hi Laurent,
Thanks for the offer. The parts i was after were spinners for the model, i managed to get a set of cowls from Richard. I have a set of spinners now but i'm sure other people will read this who would like to take you up on the offer.
I can't help thinking that it would make building this model a lot easier if it had a Fiberglass fuselage and a different system for plugging-in and bolting up the wings?
Sean.
frank fearn
Postby frank fearn » January 12th, 2014, 8:14 pm
A little more progress on the Typhoon, fuse nearly completed with the majority of riveting completed but I am now "baffled" on the best way to duct air to the motor. That huge air-intake is enormous but the majority of engine is hidden behind the spinner......experience / installation ideas are more than welcome to save me more head-scratching...
chris willis
Postby chris willis » January 12th, 2014, 10:16 pm
Hi frank, on mine I used the bottom of a drainpipe, the plastic shoe, this is behind the centre hole in the scoop, it forces air up to the fins where you can add a little ply at angles to duct it over the cylinder, mine works a treat.
frank fearn
Postby frank fearn » January 12th, 2014, 10:26 pm
:D I love you. :D .....many thanks for the prompt reply....."its only easy if you know the answer"..
I really didn't want to cut additional opening holes into that cowl ...would be such a shame...
Many thanks Chris, appreciated... :D
chris willis
Postby chris willis » January 12th, 2014, 10:40 pm
Steady on frank people will be talking :D glad to be of help..
Chris Lane
Postby Chris Lane » January 17th, 2014, 8:35 pm
Having moved house a year ago my modelling has been directed to repair of hangar rash from the removal activities and getting some sort of workshop set up in parallel with the refurbishment of a neglected bungalow.
The Chipmunk plans and laser-cut parts I bought from a fellow LMA member have now been rediscovered and work is in progress. This is the Dave Womersley 1/4 scale Nationals winner version and is strictly for builders. The pictures show the state of play. The modification of the nose from the original Laser engine bearers to a radial mounting for a Zenoah 38 can be seen and on the building table are jigs for the sliding canopy construction. Also on the table are parts for the wing centre section. This is being modified to allow the wing panels to be assembled to the centre section at the flying site prior to fitting the complete wing as a one piece unit. The structure is very light and Dave's ended up at 8.6 kg.
Q1: The plans only show the left wing - how do I go about assembling the right wing?
Q2: If I finish the model as RAF Halton Station Flight Chipmunk WB552 in its 1954 aluminium finish with yellow trainer bands will a 2.4gHz Rx work buried in the fuselage?
Chris Lane
David Jones
Postby David Jones » January 17th, 2014, 9:37 pm
Hi Chris, regarding Q1, the method I've found reliable is to wipe over the plan with a rag wetted with cooking oil or olive oil, allow the plan to dry (overnight) and, when you turn it over you'll have a clear mirror image for the opposite wing. It doesn't spoil your plan for future use. Hope this is of help, I'd be interested in any other ideas. Jonesey.
Users browsing this forum: No registered users and 110 guests
