Postby Tony Collins 1073 » December 16th, 2011, 9:25 am
Hi Dave. Finding white vulcan info is a real challenge isn't it. I expect you have been looking and probably not had much luck. Camouflage vulcans by the thousand but very little white.
XH558 was in the nuclear strike force in RAF No. 50 Squadron and its markings are hard to find.
The computer generated picture is pretty good but doesn't show everything. XH558 had The squadron crest on both sides of the fuselage at the front which some other vulcans from different areas did not.
The most difficult job has been trying to find images of The front fuselage roundel, the crest and the fin markings in high enough resolution which would enable you to have these items made in vinyl which is probably the way to go. Well I am three parts there after a long old search. The only item I have not yet located is the cross which sits high on the fin. I have got the rest in extremely high resolution which will enable you to print as large as you want with perfect copy. We are talking about 5 Meg plus files which can be made even bigger without losing anything. Luvely jubbly.
Below are examples which I have had to reduce considerably. I think you will agree they will be up to the job. In fact they actually dont look as good when they are reduced for some strange reason.
Your job now is to get the correct sizes. I would say that the pictures may help you to scale these. Maybe the jet intakes will give you some idea. Once you have worked these out let me know what they are and I will resize the images ready for production by the manufacture put them on a disc and send it too you. I reckon the the crest will be between 6 to 8 inches tall and you can compare them to the roundels when you have worked them out. Dont forget the wing roundels - not sure yet what size they will need to be.
I hope this will be OK for you.
Cheers Tony.
PS. Sorry about fun stuff. I've been very tied up lately now both my thumbs are working again, [Titanium]
PPS don't forget that XH558 letters went underneath both wings too. Imagine that, looking up on a slow pass seeing those letters.
- V2a.jpg (35.92 KiB) Viewed 14901 times
- 1946Waddington20VulcanXH504.jpg (34.13 KiB) Viewed 14901 times
- V8.jpg (122.37 KiB) Viewed 14901 times
- V10bc.jpg (48.54 KiB) Viewed 14901 times
- Vulcan nose b.jpg (54.95 KiB) Viewed 14901 times
Tony Collins 1073 on December 16th, 2011, 12:35 pm, edited 5 times in total.
