I have now finished the undercarriage design and will be making it from SS tube, TIG welded together as a faithful copy of the full size. For the wheels I noticed that TNT sell alloy 8" wheels but 2 problems with these. Firstly they are not scale and secondly would cost over $400. Hence now started making my own. I found that on Ebay you can buy a set of 4 8" wheels for just £20.....
- Set of 4 Pneumatic 8_ Wheel.._Page_1.jpg (11.25 KiB) Viewed 16957 times
Each wheel weighs 998grams. The hub however is 568grams.
Once taken apart I have got inner tubes and tyres ready for some alloy hubs....
- 8" tyres
- IMG_2504.JPG (35.06 KiB) Viewed 16957 times
The alloy hubs will be 2 piece, screwed together with small grub screws. The axels are 15mm SS tube (scale) with 21mm OD bearings. So far I have machined one hub, but not yet parted it into its 2 pieces, so it is curtrently 3mm (parting tool thickness) wider than it will be when finished. I have left it whole for now because I want to drill and tap the small holes first.....
- alloy hub 1
- IMG_2502.JPG (29.49 KiB) Viewed 16957 times
You can just see the flange of the outer hub inside the bore below. that flange will be parted off with the outer half of the hub.
- alloy hub 2
- IMG_2503.JPG (27.31 KiB) Viewed 16957 times
Current weight of the hub is 356grams, but this will be lower when parted off and with the addition of some large holes drilled through the centre.
