Another 1/4 Scale Sea Fury
Re: Another 1/4 Scale Sea Fury
Postby Alan Cantwell 1131 » January 8th, 2011, 10:17 am
Trevor you say you dont know why you are bothering with unseen detail, reminds me of when i went to the IPMS nationals, a while ago( a must see event, if you are a modellor of anything ) a chap was doing a build of a atchbox large series Lysander, in the fuzz, he was istalling all sorts, oxygen bottles at the rear of the fuzz, etc, i asked him why, wen the detail cannot be seen, his answer ? i know its there, such was the pride in his work, your like that, on the same day, i stopped by a display stand, to see a three leg jet undercart sitting on a polished wooden plinth, but no aircraft, whats this, i asked? stealth fighter he say :D :D :D :D i was about the 20th today that got caught out!!!!!!
Mark Partington 2989
Postby Mark Partington 2989 » January 8th, 2011, 10:52 am
There was a 1/4 Sea Fury on the Mackay stand at Cosford a couple of years ago - looked gorgeous it did :D
Which one of these is that one?
Mark
Mark.
Tonka Toys, Big Boys Toys
Postby Phil Clark » January 8th, 2011, 4:28 pm
Mark Partington 2989 wrote:There was a 1/4 Sea Fury on the Mackay stand at Cosford a couple of years ago - looked gorgeous it did :D
Mark
...that's the one Trevor now has Mark.
Trevor Wood
Postby Trevor Wood » January 18th, 2011, 10:39 am
Hi All
Have been away on business for the past week so not much done I'm afraid,however grabbed some time on Sunday and installed the main instrument dash,gyro gunsight,cockpit floor,rudder pedal scuff plates and the right hand control panel - a couple of shots to show how it is coming,left hand control panel and throttle quadrant to be completed and installed next.
Will be moving onto the pilot figure this week which as mentioned previously will use an Aces of Iron 1/4 scale WWII bust as a base,with a blue foam torso together with arms/hands and boots from the 1/4 scale Indiana Jones doll bought for £20,unfortunately you could not really use this figure in a model out of the box since it is so heavy.
If the results work out OK will post a few pictures.
Trevor Wood LMA 687
Sea Fury 5 - 2011 010.jpg (64.33 KiB) Viewed 16853 times
Sea Fury 5 - 2011 001.jpg (66.55 KiB) Viewed 16853 times
mick burrell
Postby mick burrell » January 18th, 2011, 5:52 pm
Not very impressed Trevor, you can't cheat by showing us pictures of the real one!!
m
Trevor Wood
Postby Trevor Wood » January 21st, 2011, 9:43 am
Hi All,
Well I have spent a bit of time this week working on the pilot figure which as mentioned previously was always going to be something of a Frankenstien affair,since unfortunately I have been unable to source a reasonably convincing full body 1/4 scale Warbird pilot from any where on the planet,so I have ended up making my own using an Aces of Iron 1/4 scale WW2 head and shoulders resin moulding as a base, extending the body with blue foam and then grafting on the lower arms and hands together with bits of the clothing from the cheap 1/4 scale Indiana Jones doll which is readily available.
The finished body was sprayed with humbrol enamel which has taken quite well to the clothing,the rest of the figure,head,life vest and straps etc have been painted in enamels and artist oils,a little bit more fine detail painting will be done together with work on the goggles to tone down the blue before 5 minute clear epoxy is applied to create the lens,the finished figure is also extremely light.
A few pictures taken late last night of the thing in 'the office' - hope to get the cockpit finished next week,with only the control column,seat/harness and the left hand instrument panel remaining.
Regards Trevor Wood LMA 687
Sea Fury 7 007.jpg (57.37 KiB) Viewed 16776 times
Sea Fury 7 010.jpg (66.18 KiB) Viewed 16776 times
Sea Fury 7 004.jpg (63.01 KiB) Viewed 16776 times
Sea Fury 7 001.jpg (65.06 KiB) Viewed 16769 times
Postby Mark Partington 2989 » January 21st, 2011, 12:29 pm
As I said above Trevor, I saw this one a couple of years ago at Cosford and thought it was stunning, so I'm really looking forward to seeing it when it's finished :D
Mark
Mark.
mick burrell
Postby mick burrell » January 21st, 2011, 5:45 pm
Very nice Trevor looks fantastic! Just one small point, the windscreen frame should be black.
m
Trevor Wood
Postby Trevor Wood » January 28th, 2011, 10:14 am
Managed to grab some time this week and have almost completed the cockpit and pilot,a few shots below,for those interested the control column was made from an ali tube with the handle carved from balsa then soaked in thin cyno,the gaiter is from blue foam coated in epoxy,a seat was made along with the left hand side instrument panel and throttle quadrant etc ( most of which cannot now be seen ) - the seat harness used bits of ali,paper clips and ribbed tape.
Also managed to locate a bit of North Korea map circa 1950.
Will try and get the model completely assembled and get a few shots in the near future - test flights are going to wait until the climate warms up a bit.
Sea Fury 8 011.jpg (70.05 KiB) Viewed 16701 times
Sea Fury 8 010.jpg (68.93 KiB) Viewed 16701 times
Sea Fury 8 008.jpg (66.88 KiB) Viewed 16701 times
Postby Andy Boylett » January 28th, 2011, 12:27 pm
Wow, looking fantastic Trevor. I had sent some of my friends a limk to my build thread and after looking at this site they then emailed me back to say that they liked yours !! :D
Regards, Andy
Postby Alan Cantwell 1131 » January 28th, 2011, 2:39 pm
Trevor, please stop posting these superb shots, of a superbly worked superb subject, your making me all giddy, and the drool is soiling my clothes
Korean map indeed :shock: :shock:
Trevor Wood
Postby Trevor Wood » January 31st, 2011, 12:14 pm
Andy and Alan - appreciate your feedback regarding the Sea Fury,hopefully some of the short circuit detailing techniques I have mentioned in my various posts may have been of some use to others - that's part of what the forum is all about afterall - will comply with your request Alan - don't want excessive soilage on my hands !!!!
Chris Lane
Postby Chris Lane » January 31st, 2011, 6:13 pm
Brarn boots - is that right!
Postby Alan Cantwell 1131 » January 31st, 2011, 8:14 pm
Dont you dare stop putting pictures of this magnificent machine on here Trevor,
Trevor Wood
Postby Trevor Wood » February 24th, 2011, 10:09 am
Well the last few weekends have for me still been too cold to stand around on an airfield so I decided to embark on the task of applying rivet detail to the Sea Fury,now since this model already has it's final paint finish the tried and trusted method of a soldering iron and sharpened brass tube could not be used being far too aggressive so another method had to be found,out of interest on the full size airframe the vast majority of rivets are flush and about 1/4 inch diameter and spaced between 1 to 2 inches apart depending on where they are located,so on this 1/4 scale model that translates to 1/16 inch diameter and 1/4 to 1/2 inch apart.
The shear number to be applied onto this 115 inch span by 100 plus inch long model then dawned on me,so I needed something which would allow positioning the rivets accurately,be reasonably quick in application and of course look OK,I ended up producing jigs from 1 mm clear plastic sheet around 3/4 inch wide of various lengths,these have rows of drilled holes set at the scale rivet spacing and of a diameter which allows a 1/16 inch ( or larger for fasteners etc ) sharpened brass tube to be rotated in the hole,the clear plastic jig can be positioned accurately on the model and held by a couple of bits of masking tape,the sharpened tube can then be gently rotated in each hole,the key with this technique through practice is to achieve a good scratched rivet on the paint surface and not to apply so much pressure that you bore through the paint,the epoxy glass cloth surface and the balsa airframe below,putting a few small notches or teeth onto the end of the sharpened tube helps scratch rather than cut into the surface.
The scratched rivets can then be highlighted with a paint wash as required to get them to stand out a little more ( thanks Phil Clark and Ian Redshaw for the advice here) or they can be left as produced,a few pictures of the cowl and centre fuselage section show the results of a couple of evenings work once the technique had been established.
Hope this may be of some use and interest - there is however I have to say a lot of these damed things and I ain't touch the wing yet.
Sea Fury 9 002.jpg (50.77 KiB) Viewed 16459 times
Sea Fury 9 006.jpg (60.31 KiB) Viewed 16459 times
Sea Fury 9 009.jpg (57.9 KiB) Viewed 16452 times
Postby Phil Clark » February 25th, 2011, 10:46 am
NICE :D
Postby stewart clifford » February 26th, 2011, 12:44 am
Trevor, if the LMA dished out awards for model of the year you would have 1st place for the Corsair and 2nd place for this Fury. Do everyone else a favour and don't make anything else 'till next year.
Ken Bones
Postby Ken Bones » February 26th, 2011, 9:01 am
Agree with Stewart 100%
Bonzey
Trevor Wood
Postby Trevor Wood » February 28th, 2011, 12:59 pm
Stewart and Kenny,
Steady on guys nice as it is to read your generous comments please remember that the bulk of the work on this Sea Fury ( like most of it ) is down to Tim Simmonds,who expertly built the airframe and glass clothed/prepared the structure prior to spraying by Roy Hill,hopefully the finishing/detailing work I am now applying to this model is adding to their efforts.
The riveting process has continued over the weekend with the fuselage now complete - I have to say that although this process is very much an exercise in endurance the results are pleasing,with areas of the model now starting to look a lot like the full size depicted on the excellent photo's supplied to me by Phil Clark.
Trevor Wood
Postby Trevor Wood » March 10th, 2011, 10:16 am
Hi All,
Have been continuing applying rivet/fastener detail along with some additional weathering to the Sea Fury,the fuselage and tail section is now complete - a couple of photos of the tail section attached.
The 3 wing sections are now being worked on and should be complete within a week or two and by then hopefully the weather will have settled to allow test flying.
Sea Fury 10 002.jpg (53.42 KiB) Viewed 16211 times
Sea Fury 10 006.jpg (50.17 KiB) Viewed 16211 times
Users browsing this forum: No registered users and 72 guests
