13.54% Nimrod MRA4
Mike altham
Re: 13.54% Nimrod MRA4
Postby Mike altham » February 13th, 2011, 10:06 pm
Hi mate
The pics will hopefully be up tomorrow when I get to work.
It's huge. Looks bigger than when on cad haha.
Mike
Mike altham
Postby Mike altham » February 14th, 2011, 12:16 pm
Here are some pics.
Mike altham
Postby Mike altham » February 14th, 2011, 12:18 pm
more
parts being cnc routed
mid fuse and tail section
Paul Holt
Postby Paul Holt » February 14th, 2011, 6:55 pm
Wow, looks excellent!
Mike altham
Postby Mike altham » February 15th, 2011, 7:09 am
here are some more pics of the centre section and partial outer wing.
excuse the mess haha
Mike altham
Postby Mike altham » February 16th, 2011, 12:06 pm
The glue arrived last night,
Just need wing tubes etc now.
Mike.
Mike altham
Postby Mike altham » February 28th, 2011, 8:20 am
Hi Guys,
Since registering the model I have been busy whittling away.
It has gone together eally easily suprisingly.
Here are pics of the build so far.
Its ashame of all the scrap wood you get from something this big.
nim 40.jpg (25.55 KiB) Viewed 19116 times
Mike altham
Postby Mike altham » February 28th, 2011, 8:22 am
All the fuse part were built inhalf to keep them straight
nim 39.jpg (27.3 KiB) Viewed 19116 times
nim 25.jpg (31.74 KiB) Viewed 19116 times
nim 22.jpg (24.55 KiB) Viewed 19116 times
Mike altham
Postby Mike altham » February 28th, 2011, 8:26 am
once all the halfs were built they were then glued together.
This was a messy process.
nim 19.jpg (32.87 KiB) Viewed 19117 times
nim 35.jpg (31.13 KiB) Viewed 19117 times
nim 20.jpg (27.47 KiB) Viewed 19117 times
nim 37.jpg (27.72 KiB) Viewed 19117 times
nim 38.jpg (24.52 KiB) Viewed 19117 times
Mike altham
Postby Mike altham » February 28th, 2011, 8:29 am
here is the trail run of the centre section. Still needs adjustment.
nim 27.jpg (28.68 KiB) Viewed 19116 times
Mike altham
Postby Mike altham » February 28th, 2011, 8:34 am
Here are pics of the sections glued and temp put together for size.
Also a pic of the machined refuelling probe. it is now covered in balsa ready for glassing.
nim 32.jpg (28.38 KiB) Viewed 19116 times
Mike altham
Postby Mike altham » February 28th, 2011, 8:37 am
pics of the nearly finished fin etc.
nim 28.jpg (32.69 KiB) Viewed 19117 times
nim 30.jpg (30.44 KiB) Viewed 19117 times
Jason Griffiths
Postby Jason Griffiths » February 28th, 2011, 8:55 am
WOW very nice :shock: :D
Thanks 8-)
Postby Alan Cantwell 1131 » February 28th, 2011, 6:19 pm
Mike, dont you think it better to have the fuzz in two bits, or even three? centre section, with front and rear bolting on? i must come up and look at this model,
Paul Holt
Postby Paul Holt » February 28th, 2011, 8:59 pm
I for one can not wait to see this finished!! Awesome!
Mike altham
Postby Mike altham » February 28th, 2011, 9:14 pm
Hi guys
Thanks. Should be at the spring do up at Bradford as it is booked in.
Hi Alan the fuse splits just forward of the wing and just aft of the wing
The outer wing panels come off which are around 7 ft long each.
The wing tip esm pods with the wingtip fences on are removable
Also the tail halves come off and the finlets to. The canoe on the top of the fin will be glassed onto the fin.
And the refuel probe is removable
Pop up when you are free just give me a bell to make sure I'm in. I'm normally in the garage for a while every night when Leanne is in work.
Mike
Mike altham
Postby Mike altham » March 2nd, 2011, 7:57 am
Just another few pics.
Half of the nose taking shape and also the ECS intake on the fin.
Mike.
Mike altham
Postby Mike altham » March 7th, 2011, 12:01 pm
A quick update,
The nose and tail (MAD Boom) now sanded to shape, the centre fuse is now joined to the centre section but still alot of work to do on this.
Mike.
Postby Phil Clark » March 7th, 2011, 8:40 pm
Mike
Maybe I'm missing something, but would it not be much easier to sheet individual airframe parts before joining major bits together?.........fuselage before centre section is added, fin before it's added to the rear fuz etc....
When building a fuselage on a vertical or horizontal crutch as you are, it's also normal to frame up and sheet one have as far as possible before turning it over to build the 2nd side. The sheeted 1st side will be very rigid making framing up the 2nd side easy. If your unsheeted structure is already stiff enough to allow the 2nd side to be built on, then I'd suggest the basic structure is rather over built and may end up a bit heavy.
Just my 2p's worth...............(Crackin project though :D )
Mike altham
Postby Mike altham » March 7th, 2011, 8:59 pm
Hi Phil
Any bit of advice is more than welcome
The fin is all cnc locking into the fuse so it needed to be built in before the sheeting could be done.
The wing as you said would have been easier doing it the way you said but as my building board is not big enough to accept the centre section wing, as I placed them together which took me over an hour as they are a really tight fit, it squared up the spars fuse etc. Leaving an aligned centre section. This weekend I will jig it up and then partial sheet the centre section to lock it in position. Also like you said. With working on the full size nimrod, I think in a few places I may have over engineered it but hopefully with taking it to the Bradford do I will get advice etc.
All advice is very welcome as this is my first over 10 ft model.
Just awaiting fuse and wing tubes. Spent all night sorting one wing u/c plate.
Mike
Cheers Phil. Just fancied doing something different that I don't think has been done before.
