Hi Robert
Thanks for reading the thread.
The images come from a stock set I have on CAD, I literally have hundreds but to be honest I've never had anyone challenge me on the wrong dial in a cockpit!! and I've done quite a few now.
I wish I'd have taken some photo's during the build (Lesson Learnt)
However the steps I take are as follows;
1 - Cut a 1/8 ply template of the instrument panel to fit the model
2 - Scan the template onto your computer
3 - Reduce and overlay the full size Instrument panel onto your scale template on CAD
(You can get most full size panels from a Goggle search)
4 - Copy your stock Dial images over the Full size dials
5 - Delete the full size image
6 - Print off the the image (x2) and there's your scale cockpit dials in the correct position.
7 - Using the 1/8 ply template mark and cut an Alloy front dash
8 - PRIT Stick the paper image printed in step 6 on the front of the Alloy Dashboard
9 - Centre Punch each dial and drill to the correct size (Usually 6,8,10 or 12mm)
10 - Sandwich the Unused Image from step 6 between the Alloy and 1/8 Ply and there you have the complete Dashboard ready to paint
For the rings I've tried several methods, I used to use copper wire wrapped around the Drill shank used to cut the hole as per Step 9 above however this meant side cutters and soldering the ends together then filling down to get a perfect circle.
I now just use solder with the same method as a knife will cut through this and leave a clean edge. These are super glued on the front of the Alloy dashboard. The added benefit is that if you are weathering and rub down your paint too much the solder is the correct colour for a weather look unlike the copper method.
I've taken some photo's of the finished cockpit but realised it's quite hard to get a good image in the garage under fluorescent lights
- DSC02742.JPG (125.78 KiB) Viewed 16037 times
- DSC02745.JPG (146.09 KiB) Viewed 16037 times
So on with the build;
Next was a complete fresh coat of primer
- IMG_0732.JPG (46.12 KiB) Viewed 16037 times
Rivet deal was added next. Flush rivets applied via a 'cheap' soldering iron with a brass 1/8 copper tube in the end.
- IMG_0143.jpg (75.59 KiB) Viewed 16037 times
Followed by Silver underneath and Dark Grey on top
- IMG_0729.jpg (96.11 KiB) Viewed 16037 times
Next was to mask the camouflage stripes which took a lot longer than planned!!
- IMG_0148.jpg (58.9 KiB) Viewed 16037 times
Looked like an artic weather scheme after this. I still can't remember giving them two time off!!
- IMG_0744.jpg (87.71 KiB) Viewed 16037 times
Couldn't help having a sneaky look prior to the paint going off.
- IMG_0157.jpg (104.6 KiB) Viewed 16037 times
Thats enough for tonight I'll finish the thread update in the next day or two.
