1/3 Scale Fokker D.V11
david clarke
Re: 1/3 Scale Fokker D.V11
Postby david clarke » March 14th, 2013, 10:53 pm
mmmmm intresting on the Mick Reeves site he suggest's a 28x12 for best performance but i think that might be on the spitfire,it also says 28x14 on the Camel takes it vertical,what weight are the Balsa USA DV11's?.
Dave.
Simon Willey
Postby Simon Willey » March 15th, 2013, 6:22 am
They are all around 40lbs ready to fly give or take a bit . As I said thats just on our 3 models , the 30x10 certainly suited our airframes better.
Simon
The Dawn Patrol
LMA No 3109
david clarke
Postby david clarke » March 16th, 2013, 5:45 pm
Done a little more today quite pleased with progress,cowl turned out to be really simple to build.It slides forward removing the front and top in one piece to give access to engine and tank bay,when it stops raining i'll get some more pics of the cowl.
Dave.
david clarke
Postby david clarke » May 15th, 2013, 7:53 pm
Actually got back onto the DV11 at last,i have made a tray that slides in and out of the top centre section to accomodate the radio for the ailerons,it does away with the servo wires from fus to top wing.All flying surfaces are now covered,started finishing fusalage today and making side pannels out of 20 swg ali.
Mark whiteley
Postby Mark whiteley » May 15th, 2013, 10:14 pm
Looking fantastic, but i would not expect anything else
Whats the finished weight going to be?
david clarke
Postby david clarke » May 15th, 2013, 10:57 pm
Hello Mark are you well,i weighed it earlier this week before i started covering it,complete without engine and it was 19.5 lb,so i am hoping under 40 finished.Have you flown the triplane yet ?.
Dave.
david clarke
Postby david clarke » May 26th, 2013, 10:31 am
Just assembled it for the first time,went together a treat,just weighed it as well 34lb less radio four servos batterys etc.
Dave.
david clarke
Postby david clarke » June 3rd, 2013, 8:01 pm
Cracked on since last post,all servos now fitted,pull pull wires all done on rudder and elevators,just waiting for some fittings to arrive to finish ailerons.Also made a duct to direct the air over the cylinder,also modified the exhaust to suit.Weighed it again today with everything in it,it tipped the scales at 37.5 lb,CG is spot on but i will add just a tad of nose weight just to be on the safe side,now waiting for the fittings and the 30x10 to arrive and i can go and play.
Cheers,Dave.
david clarke
Postby david clarke » June 16th, 2013, 7:32 pm
Well flown it today the video is the maiden flight it flew really well,it's not as agile as the DR1 and SE5 but it is much heavier at 39 lb.Engine was faultless as ZG62 normally are,2 clicks of down elavator was all that was needed and also for the next few flights i mixed 25% rudder with aileron which made a vast difference.Can be tricky on the ground if you get it only slightly cross wind,but very managable,all in all a good day.http://www.youtube.com/watch?v=E7WLSl26 ... e=youtu.be
Cheers,Dave.
chris willis
Postby chris willis » June 16th, 2013, 7:35 pm
Well done David, nice job as always.
david clarke
Postby david clarke » June 16th, 2013, 8:01 pm
Heres the second video,my little helper missed the landing ran out of battery :roll:
http://www.youtube.com/watch?v=7edqP58H ... e=youtu.be
Dave.
frank fearn
Postby frank fearn » June 16th, 2013, 8:23 pm
get ya next time Davey....if its not sold!!!!
