Wellington build and re-build
Steve Vodrey
Re: Wellington build thread
Postby Steve Vodrey » November 1st, 2015, 11:39 am
After going to Gaydon last week I returned home enthused having spoken to many fine people and seeing so all those new projects I felt the need to resume my efforts on the Wellington.
Next decision is bomb doors. They are really long and give great access but take out some strength and are difficult to hinge and operate with servos as they are prone to warping.
To avoid stalling servos and spending too long setting up the hinges I have opted to make them as per the scale size but as an enormous removable hatch. Might strengthen up the fuz depending on how bendy it is after I curt out the doors.
Comments are always welcome...
Postby Rob Buckley » November 1st, 2015, 7:55 pm
I considered bomb doors on mine...but as the full size had about 25 of them I decided not to bother & just put a small hatch in the bottom to get to the wing fixing & leave it at that!
Steve Vodrey
Postby Steve Vodrey » November 5th, 2015, 11:08 am
Thanks Rob.
Great picture of the bomb door detail.
Steve Vodrey
Postby Steve Vodrey » December 9th, 2015, 7:50 pm
I did wonder, having seen the build article by Phil Robertshaw whether to continue with this thread. The intention from my point of view is to benefit newcomers to this model type and by explaining my problems and how I get over them.
Comments are welcome of course.
Decision made on bomb doors. Will make four small ones rather than two long ones. Manual closing. They will then do for access underneath.
Next to get on with finishing the planking the fuz and get it ready for covering.Before this is done the leads need to go in for the tail feathers. I went for the Dave Hayfield twisted wires using the drill method.
Fuz wiring .jpg (39.83 KiB) Viewed 90947 times
Steve Vodrey
Postby Steve Vodrey » December 9th, 2015, 7:55 pm
Tail wheel position according to the plan is mid point between formers .
I beefed it upon a little and went for the servo mid point with a long push rod.
Thanks to Tony (Uncle Albert) Thompson for making my tail wheel assembly.
Tail wheel.jpg (32.33 KiB) Viewed 90948 times
Steve Vodrey
Postby Steve Vodrey » December 9th, 2015, 8:00 pm
Tailplane is supported by a long 12mm carbon fibre tube and a length of hardwood running from the hinge line into the fuz.
The fin detail is sparse and since I wanted mine to be removable I set about making a similar arrangement.
Fin stab.jpg (35.87 KiB) Viewed 90948 times
Steve Vodrey
Postby Steve Vodrey » December 9th, 2015, 8:17 pm
All goes together quite easily now although the tailplane for reasons best kept to myself didn't line up with the wings. I made a couple of large washers out of plywood and re-positioned the rigging holes for the carbon fibre tube sliding the washers into the correct position.
The three lengths of hardwood can now be held together using a triangle of plywood bolted through using blind nuts.
internal configuration.jpg (22.69 KiB) Viewed 90947 times
All lined up.
Tail feathers set up.jpg (35.28 KiB) Viewed 90947 times
Postby Dave Parry » December 9th, 2015, 8:38 pm
Hi Steve, don't know why you would think of stopping this thread just because it has been covered in the Journal. remember not all forum members belong to the LMA. I like the way you are explaining on how you are overcoming the challenges. keep up the good work, pity you didn't submit it to the Journal, but I respect your chose.
Dave Collis 2296
Postby Dave Collis 2296 » December 10th, 2015, 5:52 am
Thanks for keeping this going.
I have the SLEC kit..had it for a good number of years, and this year it is on the "to build" list...right after the 1/3 Anderson Kingfisher and Balsa USA 1/3 Fokker D-VII
Hopefully, Unitract still can provide the gear.
Dave.
Steve Ogden
Postby Steve Ogden » December 10th, 2015, 6:17 am
Unitracts will still make you the retracts. But be aware it can take2 months plus to get them. Cost me £360 for a set just a few weeks ago.
Steve Vodrey
Postby Steve Vodrey » December 11th, 2015, 1:31 pm
With the wiring done, tailwheel and tail feathers secured I can complete the rear planking.
Rear fuz planking completed.jpg (34.33 KiB) Viewed 90820 times
Steve Vodrey
Postby Steve Vodrey » December 11th, 2015, 1:32 pm
At the front I opted to make a sliding tray to hold the batteries, switches, air tank and retract valve with servo. Ballast can be fitted to this tray underneath. One again not much detail on the plan so it's a case of doing what suits your needs.
Although this model should be underweight i'm going for two receivers which helps split the load of the 13 servos.
Battery and accessory tray.jpg (30.31 KiB) Viewed 90820 times
Steve Vodrey
Postby Steve Vodrey » December 14th, 2015, 8:25 pm
Back to the nacelles. Engines now fitted. The rectangular plate that comes with a Zenoah 23 or 26 cannot be used really as the four mounting holes foul the plywood sides of the nacelle box. It could be re-drilled of course but taking it off reduces the overall length which makes it a perfect fit anyway. I simply put the three bolts through from the inside.
engine mounted up.jpg (36.4 KiB) Viewed 90758 times
Steve Vodrey
Postby Steve Vodrey » December 14th, 2015, 8:34 pm
I always make it a rule that I have access to everything if I need to.
The tanks at 500ml will run the engines for more than long enough. I can slide them up to the far end of the recess. Access to them will be via a hatch underneath so as not to spoil the top surface.
Throttle servos can be mounted on the bulkhead so as to avoid bell cranks that only add slop to the linkages which isn't great (especially on a twin).
tank access.jpg (35.19 KiB) Viewed 90758 times
Steve Vodrey
Postby Steve Vodrey » December 15th, 2015, 5:57 pm
Time to do the bit I have been putting off...
The nacelles.
Formers soon go into place. The CNC parts really fit well.
Dreaded planking to follow.
ready for planking.jpg (33.42 KiB) Viewed 90722 times
Steve Vodrey
Postby Steve Vodrey » December 18th, 2015, 5:05 pm
Planking done now.
Two days work.
Ridiculous amount of time.
Back to the fuz next week and get it all ready for covering.
completed planking.jpg (24.02 KiB) Viewed 90665 times
Steve Vodrey
Postby Steve Vodrey » January 8th, 2016, 5:34 pm
Now that all that silly hat and tinsel business is done with it's back to the building.
Elevators, rudder and ailerons now fully completed ready for covering. Another job that took far too long.
Anyway. Decision made on bomb doors which are a total of 38 inches long. As pointed out earlier in a helpful post they were infact a combination of up to 25 separate doors so I opted to build in the front half completely and make a pair of the back end giving access to the wing tensioners, connecting cables and two receivers which are in the centre of the fuz.I intend to hinge them and use catches not bothering with servos. Got no spare channels anyway as I have opted for six and seven channel receivers...
paul needham
Postby paul needham » January 9th, 2016, 10:41 pm
Looking good Steve, giving me the urge to get mine started.
Steve Vodrey
Postby Steve Vodrey » January 10th, 2016, 4:50 pm
Thanks Paul.
Cowls from Vacform are great by the way. They have saved me loads of time and fit really well.
Steve Vodrey
Postby Steve Vodrey » January 29th, 2016, 4:34 pm
After a lazy week away it's time to get back into this.
Time for all those dreaded strips on the fuz.
Front planking.jpg (38.04 KiB) Viewed 90190 times
