1/4 scale Mk.1a Spitfire
Re: 1/4 scale Mk.1a Spitfire
Postby Phil Clark » February 2nd, 2009, 9:39 pm
Jason Griffiths wrote:Looking good looking good
How much will this Spit be retailing for :idea:
At present, we have no plans to 'kit' the model....................
Jason Griffiths
Postby Jason Griffiths » February 2nd, 2009, 10:16 pm
Oh right it's looking good i must say :D
Have you got a target in mind for the finishing date ?
Thanks 8-)
Postby Phil Clark » February 4th, 2009, 8:21 am
Ali & I are competing in 'Team Scale' at Top Gun (Florida) 2nd weekend in May.....so we have about 2 1/2 months tops to get her finished to leave a few weeks 'practise' time.............
Ploughing on with more of the internal detail at present............
Jason Griffiths
Postby Jason Griffiths » February 4th, 2009, 9:00 am
Are you going to be leaving it Silver or are you doing camo :?:
Thanks 8-)
Postby Phil Clark » February 5th, 2009, 10:06 pm
It's being finishes as Mk.1a 'AR213'........still flying and current based at Booker. Modelling a 'current' example makes the producing the documentation for statc judging a whole lot easier as opposed to modelling a 'wartime' example where details on colour etc... can be rather sketchy.
jimlambert
Postby jimlambert » February 6th, 2009, 5:09 pm
Phil........ Do you make that piano hinge or is it available commercially ??? ..... Jim
P.S. Engine bits arrived .... Ta
Postby Phil Clark » February 6th, 2009, 6:14 pm
Nelson Hobby Supplies in the US...............
http://www.nelsonhobby.com/piano.html
Henry Cooper
Postby Henry Cooper » February 7th, 2009, 7:29 pm
Phil,
As usual another stunner in the making! Are there no ends to your talents?
With all those speakers, you could do DJ'ing on a Saturday Night? :idea:
H
Postby sean smith » February 15th, 2009, 5:25 pm
Lovely Spitfire Phil. Is Jerry Nelson still supplying parts? I have emailed him several times regarding an order i placed and paid for last year (March) which still haven't turned up.
Sean.
Postby Phil Clark » February 15th, 2009, 9:50 pm
No idea.......the hinge I got was purchased several years back and has been sitting in my bits box looking for a good home. Not aware of any supply issues, so can't help....sorry.
More good progress on the Spit over the last few weeks. All servos and wiring are in, as are the Rx's, switches and batteries. The full '3 speaker' sound system has been run (out of the model......& sound great) and we're about 50% done on it's install. Flaps are now permanantly fitted...including the functional 'gull-wing' inboard section which has proved a bit of a chew on!!! Ailerons to follow in the bext few days.
Hacker have agreed to switch the 200/6 motor for the newer 200/8 motor....this should sole our excessive current draw issues and allow us to run the full 14s cell set-up on the 32" three blade solo prop without frying the ESC.
More internal detail is now well on.....all fuselage bulkheads visible through the cockpit are complete and ready to be installed, the door is finshed (and fully fnnctional!!), and the rudder pedal and gunsight assemblies are all under construction.................
Postby Phil Clark » February 15th, 2009, 9:51 pm
A few more..............
Jason Griffiths
Postby Jason Griffiths » February 15th, 2009, 10:29 pm
I love it :D
Thanks 8-)
Postby Phil Clark » February 21st, 2009, 11:45 pm
Sound system now fully installed...............
3 x 4" dia 'Visaton' speakers run via a Thomas Benedini 'Mini TSB' soundcard & 3 x 40W power amps off a 4s 4,500Mah Lipo. Test are showing 1 speaker is prducing around 101dB at 1m, so with 3, we hope to be between 105 and 106dB range. The 2 speakers in the centre section use the forward fuselage as a sound box, and also have mesh 'grills' in the underside of the wing. The 3rd speakers is mounted inside the large underside wing radiator, with the other 2 power amps inside the oil cooler rad.
Postby Phil Clark » February 21st, 2009, 11:47 pm
Gunsight & compass detail complete and ready for paint...................
Postby Phil Clark » February 21st, 2009, 11:49 pm
Some of the components for the pilots seat.....and main bulkheads 11 and 12 installed in the fuselage.........
jimlambert
Postby jimlambert » February 22nd, 2009, 7:20 pm
Phil.... Are you bringing the Spitfire to Wigan ?? Fantastic work ..... Jim
Postby Phil Clark » February 24th, 2009, 8:32 am
All being well....yes
Jason Griffiths
Postby Jason Griffiths » February 24th, 2009, 9:41 am
Looking good Phil 8-)
Thanks 8-)
Postby Phil Clark » February 26th, 2009, 9:05 am
Seat and control column about done.................
Postby Phil Clark » February 26th, 2009, 9:06 am
Seat frame..............
