My New Toy
Re: My New Toy
Postby richard armstrong » June 14th, 2016, 5:20 pm
paint job done now need fitting
but have to finish part rewiring dh chipmunk
chris-berry
Re: My New Toy
Postby chris-berry » June 15th, 2016, 7:36 am
Have you weighed it yet?
When you do fly it, make sure you get it rolling, don't haul it off too early and you'll need to use the rudder in the turns, especially on right hand turns. All the aileron and rudder to you can get and as others have said they don't glide that well but it depends on the weight.
I had one that weighed 16lbs and had an ST 2000 and glided quite well but if its built heavy then it won't glide much at all. Make sure you're wires are connected correctly and there is no twist in the wing once rigged and check and re-check the CofG!!
What servos and battery are you using? I used standard 5kg on the ailerons and one 645MG on the rudder and elevators and used a HD locking switch and 3300 sub c 5 cell nimh.
Re: My New Toy
Postby richard armstrong » June 15th, 2016, 9:00 am
chris-berry wrote:Have you weighed it yet?
thanks chris
no not weighed it yet one of the last things to do with the CoG
all servos that came with the tiggie are still in place only had to change the throttle servo most are hitec 635 running 6volts 1300mah lipos x 2
ignition running 6 volts on 2000mag lipo
as for flying it I AM NOT! but i will take your comments on board regarding weight!
Chris what aileron differential did you set on the down and up?
just have to run in the engine for ground test but not a lot left to do!
look forward to seeing u at a show?
ric
chris-berry
Re: My New Toy
Postby chris-berry » June 15th, 2016, 5:40 pm
I can't remember Richard, its been a couple of years.
Re.the Hitec 635HB servos...there was a Tech notice issued by Hitec a couple of years ago saying that 635HB servos MUST NOT be used in petrol powered airframes, as the size of likely aircraft and therefore the engine is likely to cause a gear train failure. Only Metal gears should be used.
Re: My New Toy
Postby richard armstrong » June 15th, 2016, 6:39 pm
chris-berry wrote:I can't remember Richard, its been a couple of years.
thanks for the heads up
Re: My New Toy
Postby Alan Cantwell 1131 » June 16th, 2016, 6:14 am
The HS-635HB utilizes the revolutionary “Karbonite™” gear train. Karbonite™ is four times stronger than our standard nylon gears and even after hundreds of thousands of cycles it does not show any signs of wear. With a powerful motor and dual ball bearing mounted output shaft, the HS-635HB offers plenty of torque and speed. If your application requires increased speed and torque, the HS-635HB is the perfect upgrade from a standard size servo.
Applications: Heli's and Aircraft up to 72" or up to 12lbs when using just one servo per control surface.
Note: Be aware that high vibration gas (not glow) engines combined with large control surfaces and large throws (3D models) can put undue strain on the gears. Metal geared servos are recommended for these applications even if under 12lbs.
Warning: Do not use thread lockers on Karbonite geared servo as it will cause the output shaft to fail.
Re: My New Toy
Postby Alan Cantwell 1131 » June 16th, 2016, 6:20 am
Be reet, the meaning was for big aerobatic type control surfaces flapping about, be carefull with the moth when doing 3/4 throttle rolling harriers Richard, It is interesting though, you see the tested for thousands of cycles shows no sign of wear then you get the bit at the end, do not used thread lockers -- i presume they mean internal tapped locking washers? Or it will break the output shaft? Mind you, Karbonite could kill superman, or was that kryptonite?
Re: My New Toy
Postby richard armstrong » June 16th, 2016, 8:52 am
thanks alan
for the that useful information keep it up
Re: My New Toy
Postby Rob Buckley » June 16th, 2016, 2:13 pm
What they probably mean is that Loctite type thread lockers will make the plastic break, like if you spray acrylic with the wrong sort of paint.
