Next up is the fuselage. This is the first model I've worked on where the centre section (cockpit) is built first and everything hangs off of that.
Again, it went together very easily with the formers and wing mounting points being glued up with 30 min epoxy and left overnight to cure
- DSCF0802.jpg (515.8 KiB) Viewed 118186 times
- DSCF0803.jpg (522.33 KiB) Viewed 118186 times
The plans called for "
hardwood U/C mounting blocks, however Jerry boy had not specified what type of hardwood to use. A trip to a local timber merchant had sourced an off cut of seasoned mature English oak which they sized for me.
I cut the first section to the correct length which cost me a blade on my jigsaw. Bloody tough stuff!
I had to break subsequent cuts into increments to allow the saw blade to cool between cuts!
I almost killed my router cutting the slots for the U/C wires and if my milling machine had been working I'd have milled the slots!
Finally it was into the pillar drill to drill the pilot holes for the mounting screws as there was no way the screws would have had any chance of cutting their own holes.
They were then fitted to the wing mounting points with 30 min epoxy and left overnight to cure.
- DSCF0804.jpg (550.99 KiB) Viewed 118186 times
An aside, wood should be a soft enough material to be worked with wood working tools and not require metal working tools. The English among us should remember that when growing your oak! End of rant.
The remaining formers in the cockpit area were fitted and everything was given a couple of coats of grungrau using Humbrol authenticolour whilst I had easy access. The front of the fuz was then constructed directly onto the center section.
- DSCF0847.jpg (538.31 KiB) Viewed 118186 times
As the fuel gauge is a brass pipe sticking out of the top of the fuz directly in front of the forward cockpit and from what I've seen from the limited photos available, no two BU180's were exactly the same, depending on what the client wanted. Some had a recessed fuel cap covered with a flap and some had a brass filler cap sitting proud of the fuz skin.
I've not decided what I'm going to finish this one as, I only know it will NOT be D-ELIO as that is the one every other model I've seen has been finished as. (That's the reg' markings shown on the plan.)
With that in mind and not wanting to drill through an un-supported longeron, I beefed this area up with some scrap balsa.
The tray to support the fuel tank has also been fitted and covered with high density foam.
- DSCF0846.jpg (515.13 KiB) Viewed 118186 times
Next was the frame for the cowl and the aligning dowels. I skinned the top and bottom of the cowl at this stage to provide some rigidity as I'd be taking this on and off to allow for fettling the mounting points.
The plans don't show a method of fixing and all of the pictures of other models show their cowls screwed on from the side, which I did not find aesthetically pleasing to my eye. I decided to go with concealed fixing points on the rear cowl former.
I drilled four fixing points into the former and transferred the position onto the firewall before drilling out and fitting captive nuts doubly secured with epoxy. As I intend fitting working hinged panels to the cowl, this should allow easy access and keep everything hidden neatly away.
- DSCF0850.jpg (513.66 KiB) Viewed 118186 times
- DSCF0849.jpg (410.68 KiB) Viewed 118186 times
The firewall was then given a fine skim of epoxy to fuel proof it.
The plan for this afternoon is to fit and align the engine bearers and this should be the front ready to be skinned once the rear of the fuz has been constructed.
