Covering Test
I have been having a go at covering using the Diatex 1000 nylon material I have. Some of the LMA members use glues and dope in a very diluted state - glue is 50/50 with thinners and dope also 50/50. Like this there has to be
- 2 costs of dope
- 2coats of glue
- 5 or 6 coats of dope to finish
So possibly 10 coats, with light sanding inbetween each. I also noted that the people doing this are trying to achieve a very smooth finish to replicate metal. I wnat to achieve a finish the same as on a full size plane using Diatex. Now, I ntoiced on the manufacturers site that they talk about using just 2 layers of ‘sealer’ diluted 90/10. I called them and they said their sealer was similar to dope.
Ah, ha. This is worth a try. It may also be that the reason people using the 50/50 mix have to be very careful not to get drips going through the fabric is because the surface tension of the dope is greatly reduced and it can easilly leak through. I decided it is worth a go with a less dilute process so set up a test piece…
- IMG_2877.JPG (27.18 KiB) Viewed 18923 times
- IMG_2878.JPG (33.71 KiB) Viewed 18923 times
This is a 180mm square piece of very soft balsa – very soft so as to be as porous as possibe. It has had:
- 1 coat of 90/10 dope/thinner to seal the balsa
- 1 coat of glue 90/10 to stick the Diatex on
- Shrinking of the material with a hot iron
- 1 thin brushed coat of 90/10 dope in one direction
- one hour wait
- another 90/10 brushed dope at 90 degrees to the first.
The result looks good. The finish still looks just like the starting material, like it does on full size. There do not appear to be any holes. I can pour water on and nothing comes out the other side.
What do you all think? Am I trying to do it to quickyl? Should I do it with more thinner and more coats?
