Craig Green
Postby Craig Green » November 21st, 2022, 10:21 pm
Sure was and is a labor of love.
Just need some gear to get her on her feet, then I can start getting the engines sorted.
Still lots to do.
Craig
Craig Green
Postby Craig Green » August 28th, 2023, 4:54 pm
Hello all
Just doing a follow up with regards to the Lancaster.
I have weighed it and it came out to approximately 96 lbs. I am wondering what other builders came up with as a final weight?
I am also going to need to add nose weight to her. Will do some beefing up on the front end before doing so.
Has anyone else had to add nose weight and if so how much, did you have to add.
She is getting closer to completion, maiden will not be until next year as I fiddle with all the components.
Cheers and thanks
Craig
Lancaster 1.jpg (89.16 KiB) Viewed 48688 times
Peter Smedley
Postby Peter Smedley » August 30th, 2023, 9:43 am
Good luck with the maiden :D
Fly ‘til I die...
