Postby MalcolmDouglasPorter » May 17th, 2015, 12:50 pm
The workshop needs a bit of tidying up and organising again before I plod on with the skin. So I couldn't resist having a "play" in the meantime. I have been doing a little surface filling on the starboard side, and cut the window openings which I know will please some of you. I used a cutter that should go into a drill, but because of the delicate nature of the wood, decided to rotate the cutter by hand. The first few turns were rotated backwards to lessen the chance of ragging the edges, this clearly works very well. On the exit side of the cut, I held a piece of dowel against the back whilst still turning the cutter. This gave me a very reasonable edge on the inside, but needed a little fettling with a round sanding stick. I will now need to stabilise the edges of the openings with some Cyano glue or G4.
The Port Side skin will happen this coming week along side hospital visits etc.
- Cutting window openings.
- P5170234.JPG (166.66 KiB) Viewed 13690 times
- Looking good.
- P5170235.JPG (167.7 KiB) Viewed 13690 times
