Postby MalcolmDouglasPorter » June 26th, 2015, 2:30 pm
I am progressing slowly with the assembly of the wings. I am using my planned method of using the box spar as a jig. The principle is to use the datum to square everything up. This way the basic fit and squareness has to be right, but I do check the spar for squareness as I go. What is different, however, is that I will have a fair bit of "putting right" the errors in the cutting of the curves. You will notice the datum line drawn along the length of the spar. This lines up with the corresponding datum on each aerofoil frame. I am also lining up the longeron slots and various other bits and pieces as I go, one frame at a time, using common reference points. This is being done from frame No. 1 to frame No. 13, No. 13 being put on and taken off a thousand times to assist in the lining up. Once frame No. 13 is fixed, the remaining six frames will be lined up from the first 13 frames. There will then be some trimming and building up which could take ages to do. A longer sanding stick will be needed.
I accept that some of you will be throwing your arms in the air and tut tutting. This is a completely different approach to what most of you will be used to. This method is different, not wrong! I will need to compare measurements from each wing to the other, but this is not going to cause any grief. Whilst the outer portion of the wings are similar in design, I will need to use a different construction method as there will be some washout built in. I have some ideas about this which will need a building board etc. I will need to be more accurate in cutting the aerofoils for this, but I am in no hurry to make these just yet, also I have the tail plane assembly to re-design and then re-make, not to mention the thousand other things that need doing!.
Now, regarding the advice that several people have offered, I want you to know that it has all sunk in, nothing is wasted! I am using the suggestion regarding keeping the flaps portion attached during the construction. I had started to remove them from the first three frames, but this will not hinder the lining up of them later on.
- On the bench.
- P6260239.JPG (181.68 KiB) Viewed 14167 times
- Steadied in the vice.
- P6260240.JPG (201.42 KiB) Viewed 14167 times
- Datum line up.
- P6260242.JPG (172.55 KiB) Viewed 14167 times
- Foam time.
- P6260243.JPG (175.71 KiB) Viewed 14167 times
