monocoupe 90 clipped wing 26cc
Re: 110 clipped wing monocoupe 25cc
Postby richard armstrong » June 30th, 2014, 9:02 pm
pm sent barry
rob thanks i will try that as a test
alan i will take u up on that mate if i don't get sorted
Postby Barrie King » June 30th, 2014, 9:20 pm
Got your pm Richard and I can machine standoffs for you!
Barrie
Postby richard armstrong » June 30th, 2014, 9:31 pm
Barrie King wrote:Got your pm Richard and I can machine standoffs for you!
Barrie
thanks barrie see you wednseday
Postby richard armstrong » July 2nd, 2014, 11:41 am
thanks barrie for coming over and pointing me in the right direction
also for remaking the stand-offs for the 26cc, and also point out a issues that i had not even thought off with blow back from the carb in the cabin
Postby richard armstrong » August 25th, 2014, 11:21 am
update
been working hard on the coop, i was hoping to bring it to elvington ready for testing but ran into problems fitting the engine, back on track now, will be ready for next years season and i will get it flight tested, before winter set in, everything else has been set up, fitted back in after testing
engine is fitted, throttle sorted, and working needs setting up, on the TX and mechanically,
solved the choke issue, i think, but might change it, so i can use a servo, at present manual,
having to make a new barrel exhaust to fit the cowl cannot get one off the shelf to fit the engine!
the original one was a piece of tin rubbish, with a db rating of +96 so it's been binned photos to follow at my first attempted for an exhaust, on a new project
only have to fit the wind screens,
Postby richard armstrong » September 12th, 2014, 4:53 pm
update 2
all complete just need engine tuning and setting up for low and high end rpm
need help with this
then just to have it test flown any volenteers
photo to follow!
Postby richard armstrong » September 14th, 2014, 9:25 pm
engine now tun and set up
first test flight when ok but the wind blow up and filght was canned for the day
few issues to iron out larger prop require move from a 17x8 to 18 x 8 or 18x10
need to sort out a weld on the exhaust, which has a minor leek, other wise it was a good first flight
thanks to Barry for the help today at the field and for taking the time to pass on advice?
need to source a dome shaped spinner or spinner prop nut in 75mm or have one custom made to fit a falcon prop 18x8
anyone help with a on how to make one or make on for me?
did think of a albatross type spinner in 70-80mm
try standard look crap and way to big
advice would great on this point!
Re: monocoupe 90 clipped wing 26cc
Postby richard armstrong » October 27th, 2014, 7:56 pm
now up for sale
