1/3 Scale Sopwith Triplane
Dave Wood
Re: 1/3 Scale Sopwith Triplane
Postby Dave Wood » June 15th, 2013, 6:19 pm
Stunning workmanship Alan, What did you make the landing wires from?
regards Dave.
Dave Wood. 3173
AKA Woodwings.
Alan Bithrey
Postby Alan Bithrey » June 15th, 2013, 7:46 pm
Dave,
The flat wire is from Mr Reeves and the clevises were made by that nice Mr Poyser (that slowed the DH2 refurb a bit!)
Alan
Alan Bithrey
Postby Alan Bithrey » September 7th, 2013, 9:05 pm
Some more progress recently mainly centred around the undercarriage department.
U/C metalwork is finished including lots of fiddly bits like the bobbins around which the bungee chord is wrapped, the bracing wire attachments and the axles. At the backend I've made the steering arm for the tail skid and it mounting. I've also finished off the mounting for the Rotheram Pump.
Axle Pivot.jpg (19 KiB) Viewed 20763 times
UC 1.jpg (43.03 KiB) Viewed 20763 times
Taill Skid Yoke 1.JPG (20.11 KiB) Viewed 20763 times
Pump 1.JPG (15.25 KiB) Viewed 20763 times
Pump 2.JPG (16.17 KiB) Viewed 20763 times
One day I'll remember what size the photographs have to be to avoid the scroll bars. Maybe next time!
Alan
Postby Mike Booth » September 8th, 2013, 6:04 pm
Beautiful work Alan.
It's the real thing, only three times smaller.
Alan Bithrey
Postby Alan Bithrey » September 27th, 2013, 8:55 pm
The Tripehound had the chance to get its wheels on the grass at Old Warden last Sunday and it spent the morning with its friend until they wheeled it away to fly it .....
Two Tripehounds.JPG (138.07 KiB) Viewed 20637 times
Two Tripehounds 2.JPG (134.35 KiB) Viewed 20637 times
The Shuttleworth Uncovered display was absolutely cracking!
Alan
Alan Bithrey
Postby Alan Bithrey » November 23rd, 2013, 5:24 pm
Well, some of you will have seen the beast enjoying a day out at Gaydon a few weeks ago but if not, here it is.
Despite what some cheeky person said (a Jez :-p) quite a lot has been done in the last 12 months albeit mostly detailed stuff that doesn't show at first sight.
Since Gaydon I have, at last, started on the tailplane. Completely scratch built along the lines of the fullsize it is mounted using a pivot off of the front spar and an adjustable attachment (still to be devised) at the rear to enable the trim to be set although, unlike the fullsize, only on the ground. Probably be the elevators next. They will be a very similar to the rudder, fabricated out of aluminium tube and sheet.
Alan
Gaydon 13 Small.JPG (32.24 KiB) Viewed 20512 times
Tailplane Mounting (5) Small.JPG (29.8 KiB) Viewed 20512 times
Tailplane Mounting Small.JPG (28.98 KiB) Viewed 20512 times
Postby Alan Cantwell 1131 » November 23rd, 2013, 5:48 pm
You do know it will be a crime to cover this up dont you? tell you what, make another, just for flying,
Paul Williams
Postby Paul Williams » November 23rd, 2013, 6:38 pm
"tell you what, make another, just for flying,"
Don't say that, we can't wait that long.
Alan Bithrey
Postby Alan Bithrey » November 24th, 2013, 1:07 pm
Paul Williams wrote:"tell you what, make another, just for flying,"
Ha ha, that's given me an idea Paul. We can look at mine and fly yours anyway, if I built another the next one would be quicker (wouldn't it?)
Alan
paul needham
Postby paul needham » November 27th, 2013, 11:21 pm
That looks really nice Alan, I must praise your attention to the detail that you've put into this model. It sure will look good in the sky.
Alan Bithrey
Postby Alan Bithrey » December 20th, 2013, 5:29 pm
Started rustling up the elevators the other day. Outline fabricated from round and streamlined ali tube with C section ribs folded up from thin sheet. The whole lot was then Alutited together.
Going to need some more soon! Where's that chap from Sweden?
Bonzey - Can I pop round sometime so that you can give it and the tailplane the once over?
Alan
Elevator (2).JPG (23.43 KiB) Viewed 20301 times
Elevator (3).JPG (25.08 KiB) Viewed 20301 times
Elevator (5).JPG (26.36 KiB) Viewed 20301 times
Elevator (7).JPG (25.69 KiB) Viewed 20301 times
Ken Bones
Postby Ken Bones » December 20th, 2013, 8:02 pm
Give me a call Alan to arrange.
Bonzey
Alan Bithrey
Postby Alan Bithrey » February 25th, 2014, 9:24 pm
Went to see Bonzey a while back. He was happy with the tailplane and elevators. We decided that the trailing edge to rib joints needed a bit of re-enforcing with carbon tows so that was done.
Elevator Hinge.jpg (115.94 KiB) Viewed 20103 times
That nice Mr Redstraw made a rather excellent suggestion of using re-shaped steel split pins for the elevator hinges. Their use minimises the size of holes drilled in the trailing edge and once the tails are folded back around the trailing edge and then bridged with solder they aren't coming out. I have to say they work a treat and look just like the real thing (because they pretty close to how the fullsize was done).
I've at last covered the tailplane and one of the elevators (must do the other one) and it's moving on a bit.
Covered Tailplane (2).JPG (148.6 KiB) Viewed 20103 times
Covered Tailplane (4).JPG (146.45 KiB) Viewed 20103 times
Many Sopwiths; Triplanes, some Pups and, I think, 11/2 Strutters make use of a device to adjust the incidence of the tailplane by means of a rotating jack type device operated remotely from the cockpit via a hand wheel and wire rope. The rotating part of the adjuster forces a vertical rod to which the elevator's trailing edge and upper and lower rear bracing wires are attached thus adjusting the incidence without effecting the bracing wire tension - very cunning!
Anyway, I needed to replicate this albeit only semi functional. Turned from Ali rod with as much material removed as possible for obvious reasons. Seems to have turned out OK. The Ali plates with holes are the lacing plates to which the fuselage covering will be attached.
Incidence Adjuster (6).JPG (173.53 KiB) Viewed 20103 times
Incidence Adjuster (16).JPG (152.19 KiB) Viewed 20103 times
And here is the real thing ....
Alan
PS Wish I could get rid of the scroll bars on the photographs!
Alan Bithrey
Postby Alan Bithrey » September 21st, 2014, 7:32 pm
A bit of an update on the progress on the Tripehound. I'm trying to finish off the fuselage, things like the top decking, interplane strut mounting, sorting out the control runs, mounting servos, oh yes and the mounting the engine. Here's an assortment of photographs of some of the recent activity and a couple of photographs of it enjoying the Camel's company at Old Warden during the summer - even if it was in the rain! All being well, it should be trundling up the M40 to Gaydon next month too if you want to take a look.
Update 1.JPG (25.8 KiB) Viewed 19865 times
Update 2.JPG (49.5 KiB) Viewed 19865 times
Update 3.JPG (32.46 KiB) Viewed 19865 times
Update 4.JPG (32.5 KiB) Viewed 19865 times
Update 5.JPG (36.26 KiB) Viewed 19865 times
Update 6.JPG (38.59 KiB) Viewed 19865 times
Update 7.JPG (42.81 KiB) Viewed 19865 times
Update 8.JPG (38.17 KiB) Viewed 19865 times
Update 9.JPG (50.19 KiB) Viewed 19865 times
Update 10.JPG (55.94 KiB) Viewed 19865 times
Postby Alan Cantwell 1131 » September 21st, 2014, 8:50 pm
Only one word, Stunning,
Postby Rob Buckley » September 21st, 2014, 8:58 pm
It's ok I suppose, but those servo wires aren't quite the right scale shade!
Those instruments look like they will actually work...
Postby Dave Parry » September 23rd, 2014, 8:45 pm
Alan Cantwell 1131 wrote:Only one word, Stunning,
I seconded that
Richard scarbrough
Postby Richard scarbrough » September 24th, 2014, 8:11 pm
Wow, well done Alan.
Alan Bithrey
Postby Alan Bithrey » December 12th, 2014, 9:31 pm
Ken B visited the PupCam Aeroplane Factory the other week to inspect the fuselage and I'm pleased to say that it passed muster.
So, I've made a start on making it look a little different (at last!)
Covered Fus (6).JPG (47.86 KiB) Viewed 19505 times
Covered Fus (5).JPG (49.27 KiB) Viewed 19505 times
I've also been doing the rib stitching on the tailplane - seemed silly to not make it functional so a happy hour was spent with a needle and thread.
Covered Fus (11).JPG (15.04 KiB) Viewed 19505 times
Covered Fus (7).JPG (27.64 KiB) Viewed 19505 times
Covered Fus (2).JPG (31.84 KiB) Viewed 19505 times
Still a long way to go!
Alan
Alan Bithrey
Postby Alan Bithrey » November 22nd, 2015, 10:06 pm
I thought it might be time for a bit of an update!
So, first up is a cooling duct as the cylinder head is right up tight against the firewall. A hole in the firewall and sheet duct to get the air past the servos and venting out of the cockpit. The duct is in two halves and sandwiches the firewall.
Duct 7.JPG (344.33 KiB) Viewed 18548 times
Next up was mounting of the throttle and choke servos. Folded up out of yet more sheet steel, silver soldered and bolted in position.
Throttle & Choke (5).JPG (373.49 KiB) Viewed 18548 times
I've managed to shoe horn the standard Z62 exhaust in and added an additional cowl mounting ring to support the cowl and the side cheeks.
Cowl Ring (11).JPG (51.94 KiB) Viewed 18548 times
Along with other DP aircraft it's had a couple of outings to the Shuttleworth Collection fullsize air displays this year and most enjoyablle they were too.
OW July 15 (1).JPG (74.07 KiB) Viewed 18548 times
I've tidied up the wing panels (all six of them!) and tried to get them all up to the same state and started on forming the ailerons prior to cutting them free.
Wings 5 (1).JPG (58.38 KiB) Viewed 18548 times
The cowling side cheeks and top have been formed out of 18swg aluminium sheet and have made a big difference to it's appearance (at last!) I think.
Top Panel (4).JPG (43.69 KiB) Viewed 18548 times
Top Panel (5).JPG (42.27 KiB) Viewed 18548 times
And finally, I've started making the Vickers machine gun. Fabricated from Litho plate for the barrel cover, Nickel silver sheet for the back end and aluminium turnings for the front and rear of the barrel cover.
Front Ring (12).JPG (42.64 KiB) Viewed 18548 times
I've built up a bit of momentum at the moment, who knows, if I keep it up it might even be finished next year (I can but hope!).
Alan
