What's even better is that Diatex comes on 1.5m wide rolls, so there is less waste.
Before you start with the fabric, give the main surface areas a coat of the thinned fabric cement and leave the dry (only about 5 mins). I don't do the ribs, just the LE, TE and root and tip.
Then cut the fabric leaving about 2" all the way around.
- image.jpg (75.42 KiB) Viewed 25111 times
Apply a little cement to a corner of the fabric with a brush and it should 'grab' within seconds.
- image.jpg (30.96 KiB) Viewed 25111 times
- image.jpg (63.5 KiB) Viewed 25111 times
Work all the way around the wing, but don't do the ribs.. I find it just isn't necessary as the final coats of dope will do this.
- image.jpg (43.94 KiB) Viewed 25111 times
The edges were trimmed down to about 1/2" and folded over. The fabric will tend to bow out from the tight corners, this isn't a problem as the heat shrinking stage will pull it all tight.
- image.jpg (63.85 KiB) Viewed 25111 times
Don't shrink those wrinkles yet...wait until the top has been done!
I had an awkward rigging attachment to cover around. I find it easier to cut a slit first off and then slide the covering over it. Saves awkward cuts later on.
- image.jpg (43.13 KiB) Viewed 25111 times
This wing panel wasn't so tight to begin with, but I guess it proves the amount of shrinkage in the Diatex.
- image.jpg (65.38 KiB) Viewed 25111 times
Covering iron set to 120 degrees, no more than 125 degrees as this is the fabrics limit. Going over this temperature could set you up for saggy covering in high temperatures!
- image.jpg (81.72 KiB) Viewed 25111 times
I shrank both top and bottom sides as evenly as I could to try to avoid any warps... I think it worked!
- image.jpg (73.6 KiB) Viewed 25111 times
