Sky 120 LMA Trainer
Geoff McVey
Re: Sky 120 LMA Trainer
Postby Geoff McVey » July 29th, 2018, 8:19 pm
Fuselage Step 16
Fuselage bottom rear panel glued in place, good tight fit with no problems.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:23 pm
Fuselage Step 19
Fuselage corner support stripes cut from part MF2 and glued in place between parts F4 to F9 and F9 to F10.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:26 pm
Fuselage Step 20
Part F23 front top panel, glued in place, good fit.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:29 pm
Fuselage Step 21
Part F22 rear top panel, glued in place, good fit.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:34 pm
Fuselage Step 24
Will cut these panels out both sides of the fuselage to mount the servo's direct to the elevator.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:36 pm
Fuselage Step 25
Part H2 hatch glued in place, and lightly sanded, a little more needed.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:39 pm
Fuselage Step 25
This area has been sanded so that the removable hatch has a good fit.
Geoff McVey
Postby Geoff McVey » July 29th, 2018, 8:42 pm
Fuselage so far as it is weighs 2.383 kg or 6 lbs 4 oz.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 7:32 pm
Fuselage Step 22
All the lightning panels in parts F2 - F8 and F22, F23, F24 have been removed.
Only saved 189 gramms.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 7:35 pm
Fuselage Step 23
Parts F11 and F12 glued in place at the rear of the fuselage, the origional parts F11 and F12 I did not use because they were a little on the short side and the angle that they are glued in, made 2 new parts F11 and F12 from scrap material.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 7:38 pm
Fuselage Step 25
Part H2 glued in place, part H1 trimmed to fit snug with both sides of the fuselage, the top of part H1 still needs to be trimmed, but this will be done once the wing is complete and a dry test fit has been done.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 7:59 pm
Fuselage Step 26
Parts F28, F29, F30 and tailwheel unit ready to be assembled.
Parts F28, F29 glued to part F30.
Second F30 glued in place with tailwheel unit between parts F28, F29.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 8:08 pm
Fuselage Step 26
The photo below is the plan view of the tailwheel unit.
The part was then placed over the plan as you can see, towards the top you can see the swg is bent at a 90 degree angle it's approx 6mm to 7mm too short, and because where the 90 bend is the end of the swg is very close to the bottom of the fuselage, towards the bottom looks like this area is too long where you would place the tailwheel.
This is a dry test fit so you can see more clearly the picture.
Question, do I see if I can get this part again from Slec, or make another one from scratch making sure it's the correct size.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 8:19 pm
Tailplane Elevator Step 51
Parts T1, T2, T3, T4, T5 ready to be assembled.
Parts T1, T2, T3, T4, T5 glued in place.
Parts T1, T2, T3, T4, T5 lightly sanded both sides, good fit, no gaps.
Leading edge of both elevators, sanded.
Trangular plywood parts T10 added to both sides of the elevator, hinges ready to be added.
Postby Alan Cantwell 1131 » August 1st, 2018, 8:22 pm
The new one would prob be the same, bend the 90 degree bend parallel with the bottom of the rudder, glue some brass tube into the rudder to take the piano wire, have the wire free running into this tube, Your work is very neat, looks great, bet your enjoying yourself!
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 8:27 pm
Fin Rudder Step 52
Parts T5, T6, T7, T8, T9 ready to be assembled.
Parts T5, T6, T7, T8, T9 glued in place.
Parts T5, T6, T7, T8, T9 lightly sanded both sides, good fit, no gaps.
Leading edge of the rudder sanded.
Triangular parts T11 added both sides of the rudder, hinges ready to be added.
Geoff McVey
Postby Geoff McVey » August 1st, 2018, 8:39 pm
Alan Cantwell 1131 wrote:The new one would prob be the same, bend the 90 degree bend parallel with the bottom of the rudder, glue some brass tube into the rudder to take the piano wire, have the wire free running into this tube, Your work is very neat, looks great, bet your enjoying yourself!
Hi Alan,
That's what I was thinking bending the 90 degree bend parallel with the rudder, will do what you have suggested gluing a brass tube into the rudder.
Now that the tailplane, elevator, fin and rudder are complete and have done a dry test fit, a little more sanding is needed, starting to see how big this model is.
Yes, it's a joy to build this kit, I already have 1 or 2 ideas for my next build, but will finish this kit first.
Thank you.
Postby Alan Cantwell 1131 » August 2nd, 2018, 6:20 am
Whoes Dave?
Postby Alan Cantwell 1131 » August 2nd, 2018, 6:21 am
What are you thinking of covering wise?
Postby DAVE JOHNSON » August 2nd, 2018, 7:41 am
Geoff----glad you are enjoying your 120 build---here are a couple of pics from yesterday---this is the original 120 kit suplied to the LMA by Slec for a test build----4 of us built it in my workshop over 2 nights---its had a hard life opening the trainer slot at shows for many years---then spending a few years at waterplane events with some Cub floats on---and now reborn as the new PC Plod and test flown yesterday----getting a bit overweight now----but if you keep the finishing light you will find it a joy to fly
plod 2resize.jpg (75.4 KiB) Viewed 102899 times
plod 1resize.jpg (69.56 KiB) Viewed 102899 times
